Fs: Uma Highflow Racing Oil Pump
TryX
This mod is a must for highly modify bike! Nearly every bike in Malaysia (Cubprix) circuit race use this oil pump to prevent the bike from engine break down. Good products!
TryX
I'm using the oil pump now. My mechanics done some small modifications to the Oil drain of the engine, to enhance the performance much more. This UMA PUMP have different gear compare to stock. Which aloud more oil to go in. Furthermore the hole of the pump compare to stock is bigger by 2mm. Everybody must have thought why not i drill the hole bigger? Yar you can drill the hole but still the stock gear is different from UMA. UMA gear aloud more oil to go in. Why you want change to this filter?
My Personal Feedback
1. More oil can circulate in the engine so this will reduce heat on Oil
2. Cooler oil that circulate in the engine will contribute to increasing horsepower.
3. Higher Durability and Efficiency.
4. Is a must for big bore kits. Even brand like Kitaco and Takegawa include this oil pump for they bigger cc big bore kits.
5. Value for money.
rowan
5. Value for money.
can you share the modification ur mech done to the OIL DRAIN tanx... uma user too;)
