hard shifting gear
frdnnd_ferrer
sir, its hard to shift/change gear to second specially morning when i started my sniper 135 yamaha eventhough i warmed it up for five to seven minutes, how can i make it easier to change gear? what will i do? please help me. i'm just a rookie here. thanks and more power. by the way mine is an automatic clutch type.
wingman44
That's highly irregular. You should be able to shift the gears around even when the engine is cold and even if the engine is not running.
I suggest that you go and see a really reliable T135 mechanic instead of guessing and experimenting about what to do with your bike.
Also, it is quite difficult for us to give you a definitive advice on how to fix your bike without thoroughly checking it out.
wingman44
Rjloks said:
sir wing man diba mahirap talaga i kambyo ang matic??? medyo matigas?
A/C gamit ko regularly pero hindi ko na-encounter na mahirap magkambyo.
In fact, naka rear set ako for as long as I can remember pero never pa kong nahirapang magkambyo.
Ngayon ko lang narinig na mahirap ikambyo pag matic.
Rjloks
as i experience kasi sa motor ni boneslee medyo matigas yung kambyo nya.
hes using x1r rearset. and sniper A/C
wingman44
Ganun ba?
May adjustment sa clutch ng sniper a/c. para mapalambot ang shifting ng kambyo. Madali lang gawin ito. Kahit sinong mekaniko magagawa ito.
Kung naka- X1R RS naman siya, baka merong mali sa pagkaka install ng RS nya. Kasi yung mga kinabitan namin dito ng X1R RS, wala namang nagsabing nahihirapan sila sa kambyo nila.
raider125jeigh
baka palitin na ung langis mo..hehehe... try mo semi synth...sarap ng shifting.. kung hindi naman diyan ang issue... either sa mga nasabi nila o may dpat talaga icheck diyan
X1rCJ
naka RS ba ikaw sir TS? kase kung naka-RS ka na, may part na mahirap talaga magkambyo, meron pa kase need na i-adjust para lumambot ang shifting mo pag naka-RS na for AC sniper..
Mizpeh
Ganyan din sa akin.
Mas matigas i-shift yung sniper ac ko kaysa sa X1R na may clutch.
Ganyan din yung Sniper ko kapag umaga, yung first shift ko from 1st gear to 2nd gear matigas minsan hidni ko pa maipasok. Afterwards ok na.
marvymavs
Check the clutch adjustment screw at the left side of the engine of your A/C Sniper. Pag masyadong nakadiin ang settings titigas ang shifting mo. Sa lahat ng a/c na moped applicable tong procedure.
Loosen the lock nut (di diyes ata na liyabe yun)
Turn the adjuster using a flat head screwdriver clockwise (in) until maramdaman mong tumukod na siya.
Then loosen it 1/8 of a turn (counter ckockwise) then tighten the lock nut.
Clockwise turn - pahigpit - pag sinagad mo titigas ang pagshift mo.
Counter clockwise turn - paluwag - lalambot pero pag sumobra magislide ang clutch mo.
HTH :)
X1rCJ
HTH :)
ei papz marvy..sama ka sa EB maya..
marvymavs
HTH :)
Naku sir gustuhin ko man hindi uubra.. nasa work ako sa ngayon dito sa global city hanggang 4am. saan ba kayo mag i-EB at anong group? sayang naman.. gusto ko pa namang makakilala ng co-forumers dito. :cry:
sniper1979
welcome to our world motorcycle riding...sniper is the best choice option to be your bike...ride safe mga bro....GOD Speed.....
mr_kulafu
HTH :)
sir, ung 1/8 turn counter ckockwise, malambot n poh b i shift un?
sir, ask ko lng, minsan kapag nagsshift ako from first gear to second gear, ang lakas ng tunog, kung sumalpak eh hnd katulad kpg nagsshift ako s 3rd and 4th gear, bakit poh kaya ganon?
LoveMeDead
yun sakin dati lumalagitik din pag change gear medyo matigas sya,, pero nun nagpalit ako langis na motul 5100 okay na shifting ko super smooth ang pasok.. sakin lang po yun, hindi ko lang lam baka may iba issue sayo.. try mo rin po muna palit, hehehe
