HAZARD LIGHT INSTALLATION
ronald031803
tama sir!! hehehe!! tnx sir sa additional info hehehe!!
ako dn nagkutkot ng sniper ng tropa ko e nilalagyan ko dn sila ng hazard and some minor adjustment.. hehehe..
sir ronald pshow nmn MC mo hehehe!! :)
bro,yang naka video mc ko yan ,stock lang
zarathos
pwede makita kung saan nakapwesto yung hazard switch for sniper? or need talaga magbutas para mailagay yung hazard switch?
mhektheone
tips on installing hazard lights..
*you need a hazard switch that has 3 wires..the seller said to me its all positive connection no negative (-)..
*new signal light relay.. i use (toto R) signal light relay.. the stock signal light relay will not work properly if hazard light is installed it will light up but not blinking..
steps..:)
1. open ur handle cover assy..
2. look for the red coupler..
3. find the signal light wire.. (green) and (brown)..
4. tap the 2 (hazard switch wire) to the (green) and (brown)..
5. then look for the wire (brown with white stripe) (magkakatabi lng po ung 3 wires n (green) (brown w/ white stripe) at (brown)) and connect to the middle wire of the hazard switch..
6.change the stock signal light relay with new relay..
7.switch on the ignition key..
8. switch on the hazard switch.. (the signal light indicator in the meter panel will not blink, only the signal lights will blink both left and right) and test it if both signal lights are blinking..
*the signal light indicator will blink only using (left) and (right) switch.. in the switch handle..
*hazard light will not work if the ignition key turned off..
hope this will help you guys.. (cnxa n po ha hirap mag english eh.. hehehe..:)
bro what wire color from the switch to be top to the step 4.it is the same color or not? TIA.
Sidro
paps pde ka gumamit ng 2 pin switch gamitan mo nalang ng 2 pcs rectifier diode (IN5401) mas cheaper e2 diagram hth. View attachment 10747
paps is this the one installed to your sniper?, cause I already try this 1 without replacing stock relay/flasher but it didnt work instead you need to pull out your signal indicator bulb at the panel to make this hazard ckt function.
sabat
i already replace my stock flasher relays w/ an aftermarket relay.
sabat
pde po sir wag lang ung diode na maliit kc umiinit yn pag masyado matagal ka naka hazard at least 5amps diode pataas para inde umiinit
copy that sir! d q pah naiinstall ulit ung hazard switch. tinest q muna s multi tester if good ung 2 diodes. sad to say defective ung isa. so, nireplace q ng bgong diode. ga2na n cguro un! eheheh!! bz p s work kya d q pah nainstall. bka ma2ya pag uwi q! tnx s idea sir! ridesafe!
bino46
change your stock flasher, install heavy duty flasher (ung nakakabit sa mga 4wheels) , snipers stock flasher relay can only operate 2 bulbs.
sabat
atlast! its working! aeheheh! pG uwi ng bhy d muna aq pumasok para mgbihis!( excited ):D baklas
agad ng motor. ( buti my duplicate key s bag q ):p . install agad ung hazard switch w/ diode. ;)
sabay start ng motor! and. . . IT'S WORKING! (my hazard lights) :D:):rolleyes:
sabat
san nyo po nilagay yung switch? pwede po makita?
ahmm! d pah xa nkafix sir! nka cable tie lng xa s may choke cable ng mc q! actually experiment q lng mglagay ng hazard light! tsaka pinagiicPan q pah rin kung san q ila2gay! ung iba kz ng butas talga s fairings!
lpsnipie_67
paps ask ko lang! pag ON yung hazard switch mo then need mo to switch on your turn signal lights nagana ba signal mo? i mean simultaneous yung 2 signal & hazard sw.? thx!
bino46
Im happy for you sir ^^ enjoy=)
sabat
pg ON po ng hazard switch derecho n ung hazard lights. pag mg left or right signal aq need pang i off ung hazard switch.
