HAZARD LIGHT INSTALLATION
Sidro
Hazard light wiring diagram. Stock indicator bulb still working without modification & hazard light working with ignition switch off.
Cathode of diode1 & diode 2 connected to left & right signal lights ( chocolate & dark green). Use 1n5401 (3ampere diode).
the flasher relay is stock right?
jangbest
Sir Thon Already Did this on my Snipy
Its works well, I used my Hazzard even if my Iginition key is off. And The diagrahm is very much simple to understand.
Sidro
what about the naughty guys that play around your bike and make kalikot on your switch and leave it on position
Hmm, your right because the flasher is directed to the battery, but we can tap this to the ignition switch instead of directing to the battery. So we can avoid this kind of incident.
thon
Well, on this case its the mc owners decision where to install the wire. But installing hazard with positive wire on the battery make you use the hazard light without turning on the ignition thus you can warn other driver when parking on the road for a while epecially at night. (for safety reason);)
Sidro
thon & ronald031803 you both have a point, now since we have the diagram modz for this, its the MC's owner descretion on which to choose. But as long as the design/modification is working and not burning. hahaha,, cheers to all. Great work thon, john_carlo etc. ooops, special mention to @ronnel_marc..:)
Airborne_Ranger
Papa Sid... can you do the Hazard system to my bike... Plsss...;):p:D
yabzkie
Where can I buy this diode and how much does it cost? And if I'm going this do I have just to say 3ampere diode or I also need to tell the code 1n5401? Tia.
Sidro
No problem, where u? hahaha:),, 09228871626
-you can buy in any electronic stores, jus t use the code 1n5401.
Sir may I ask what switch am I going to use in this? Is it the 2way or the 3way? Tia.
-you can buy a hazard switch, this switch have 3 pins and with socket already. It is available in motorcycle shops now a days..
thon
yabzkie you can use SPST toggle switch or push button switch (ON/OFF fucntion) with 3amperes rating. You can buy 1N5401 at your nearest electronics shop/store. These diodes only cost 5-10 petot each..hehe:)
Note: do not use normally on or normally off push button switch, switch should have ON and OFF fuction.
JhayBoo
Again, please edit your post,
or I will give you a warning points...thanks.
Hi all members (especially filipinos),
Please be reminded again for the nth time to
speak english in ENGLISH SPEAKING SECTION of the forum.
This is to encourage Worldwide YamahaT135 friends & share passion about our motorcycle.
Looking Forward for Understanding...
Reminder: YOU ARE ON ENGLISH SPEAKING SECTION, Please post in ENGLISH!​
Ronnel Marco
Please be reminded again for the nth time to speak english in ENGLISH SPEAKING SECTION of the forum.
thanks for the reminder sir,...
