HELP!!!!BATTERY FAST DISCHARGING USING H.I.D
mga masters pa help po!
biglang nag low bat si snipee after using HID for 1 month
8 months plng snipee ko :(
nka rekta nman po ang hid sa battery
ako kaya prob? wiring kaya?
SYANG PAPS...LYO MO KASI E..MATUTULUNGAN SANA KITA.SAME PROBLEM BEFORE PERO OK N KO NYGN.2 HOURS NA WALANG PATAYAN PERO STILL OK P DIN BATTERY KO...HIRAP KC EXPLAIN SA THREAD E...ANYWAY TRY TO FIND SOME1 NA MAY ALAM SA ELECTRICAL ASIDE SA PAG PAPAILAW NG HID....RIDESAFE...
r3xb0i
tnx sa reps paps....hanap nlng ako ng magaling sa electrician na may alam tlaga sa HID...ridesafe
JUNEX
OT:
Cutting the yellow wire from our main coil means fast charging, right? so if i forgot to turn ON my parklights it will overcharge our battery does this damage our stator coil as well? (~me nosebleed~)
actually sa akin black wire ang pinutol n then my SPDT RELAY akong kinabit pra mging automatic on/off ng fast charging rectifier....
bino46
OT:
no it will not overcharge ur battery, as long as u have a regulator working normal the battery will not overcharge even u disconnect the yellow wire from the regulator coz the yellow wire is just for the bulbs, if u disconnect the yellow wire, the bulbs (parklight,tailight, panel) wont light up not unless u connect directly from the battery.
ronald031803
bro,tama ginawa mo,just like mine i stall relay on black wire,then if you turn on the head lamp its going to cut off the black line,its gooing to fast charge up to 15volts
