tarbashjr
its all started when my brother borrowed my bike. first hindi na sya ma-start using push starter. then 2 days after, hindi na gumana HID ko. nag kukurap lang pag hi rev. afterwards, bigla nalang namamatay ang makina when in neutral. then, all lights are gone. i found out na sira na fuse. i tried to start the engine using kick, but i failed. although nagawa ko na sya dati nung first nasira yung fuse ko pero nag start naman after 1 kick. then i replaced my fuse and afterwards, the lights are ok. pero pag nagsisignal light ako, bigla namamatay yung engine. hindi ko mastart ang motor pag nakaswitch-on yung ilaw. and a red light comes out in left side of neutral light in dashboard bago mamatay yung engine. hindi ko na sya ma-start using kick. push start button and my HID not still not working. afterwards i found out that my battery is weak and wasted (GS Battery). and i replaced my battery. i borrowed some battery to my friend and i surprised that it started in 1 kick. i think it because his battery had charged already. then after a few minutes, the problem still exist. my RPM goes lower ang makes my engine off again. then i start it gain using kick, and nag start naman. but when i using my signal light, namamatay parin. so i decided to clear my wirings. removed all alarms wiring, HID wirings. removed all lights. but the problem still exist. my battery goes lower and lower. i can start my engine using battery with charge but i have to maintain my RPM to 2k. because the engine will off if i let my throttle down. i asked my friend about this. and he told me that he think the problem is my rectifier. And he told me dont use my bike if my rectifier is dead because it will make trouble in my CDI. it's that true? but, how to troubleshoot my problems or my rectifier? i afraid if i buy rectifier and thats not the problem in the end. mga master, can you help me about this? i made it in a full details para magets nyo po.
sorry for my bad english and taglish words. nosebleed na po ako nyan.
thanks in advance
thanks in advance
