ou door to door kaninang 4pm ang kinis pa tol hehe...kenshin_blade09 said:@-marlock-nkuha m nb tol?
nde ko pa kinabet busy kasi ako kanina my nagpa kabit ng hid...
nandyan pa headlight lens mo ?
nid ko sana ung headlight... try ko lagyan ng projector tong akin...kenshin_blade09 said:sbi ko nmn sau pare bagong bago yan.ksi pagka kuna ng motor ko wla pa one month pinalitan kuna yan, eheheh...
tnx ksi satisfy ka sa item ko,eheheh...kla ko maliligaw na weh, eheheh
d2 pa headlight ko tol....nid mo ba
plasma ang kasagutan paps.. :lol:ryioki1 said:mas ok sana kung my alterntive tyo sa hid.....sing liwanag pero sing lakas sa baterya.....hehehehe
HI sir kulang paba 1 his sayo 1 lang sobra lakas na ok na un sirkenshin_blade09 said:if my solution kayo mga sir or technique na ginagawa pra di ma drain battery pa share naman po. TIA
rathelyrs said:HI sir kulang paba 1 his sayo 1 lang sobra lakas na ok na un sirkenshin_blade09 said:if my solution kayo mga sir or technique na ginagawa pra di ma drain battery pa share naman po. TIA
its not just cutting red/yellow wire sir,..it has AC signal,,you still need to rectify that to make DC and useful for our battery,..DIODE will rectify that,..problem solved.wafumeth said:try removing the yellow wire from the rectifier, no more lowbatt prob ^_^
ive installed 2hids on x1,nouvoZ, Z200(motorstar modified headlight), panther200(motorstar scooter), mio mx not a problem was found, you just need an experienced installer in that case, try xiat or agentMronnelmarc_21 said:its not just cutting red/yellow wire sir,..it has AC signal,,you still need to rectify that to make DC and useful for our battery,..DIODE will rectify that,..problem solved.wafumeth said:try removing the yellow wire from the rectifier, no more lowbatt prob ^_^
thanks bro,..anyway i have intalled my hid DIY,mio and nouvo also for my friend,..and dont see any issues,..I installed it not based on advice but based on what I know and learned heheheh,..IMHO..chiglai said:ive installed 2hids on x1,nouvoZ, Z200(motorstar modified headlight), panther200(motorstar scooter), mio mx not a problem was found, you just need an experienced installer in that case, try xiat or agentMronnelmarc_21 said:its not just cutting red/yellow wire sir,..it has AC signal,,you still need to rectify that to make DC and useful for our battery,..DIODE will rectify that,..problem solved.wafumeth said:try removing the yellow wire from the rectifier, no more lowbatt prob ^_^
btw, i only use 35w hids...
