High Charge Electricity
Ericson
and also this...
bro good morning... can I ask where to find that kind of relay... I cant find that kind of relay here in my location. And about the mods you just installed, bro my mechanic didn't cut the yellow wire located near the rectifier what he did is he cut the yellow wire located at left side of the engine.. If I want to do so that mods like your what should I do.. please help me sir.. thank's for your concern..
thon
Just add SPDT relay to the disconnected yellow wire on the stator and tap the othe other end to yellow on the rectifier This will be connected to 87a &30 on SPT relay,#86 to headlight switch and 85 to ground.:)
Relay will disable fastcharging when HID not in use.
Use this type of relay.
Ericson
sir
sir i've been looking for this type of relay here in my location but I cant find it anywhere.. how much is this kind of relay sir? thank's for your concern sir... =)
Sidro
sir
you kind fin this kind of relay in any automobile shops just take note of the part number, even in acehardware or handyman.
Luigi#16
additional about sa Yellow wire cutting sa rectifier.
sorry but i didnt quite understood :) im just not good in this electrical wirings.. but my first mechanic did cut the yellow wire in the rectifier and my parklyt was always getting busted then after a month or two my HID was installed, my battery always drains.. i charged it til 11.8V then after a week it was already drain then i charged again and got drained again in less than a week.. i changed my mechanic and he said that the earlier mechanic didnt cut a wire.. i think its the yellow wire connecting to the stator (i think).. then he said my lights would get busted if that wire wasnt cut.. my friend then said it wont get drain again but if it does, maybe there's something wrong with my battery.. after 3days my battery got drained again :( is it true that the other yellow wire (other than the yellow wire in the rectifier) should bu cut?​
Luigi#16
by the way my motor is sniper mx
i have one question..i did the battery operated lights conversion by sir thon.. i cut the yellow red wire going to headlight switch and yellow red wire going down to stator has no connection..i taped it sealed...then i tapped the yellow red wire going to headlight switch to the brown wire of ignition..tested it and all lights are battery operated....now i did not do yet the fast charging conversion..the wires going to rectifier are still in place..i'm sorry but i am not an electrician..i just followed every step.. and the HID is working fine with high and low..so far so good no low bats yet but this means i am on normal charging mode? as per my understanding..
UB Sniper
yup ur on normal/stock charging mode, it doesnt change to fast charging because ur still on stock rectifier..you dont experience the lowbat yet because you havent tried to use the hid for 2hrs or more i guess hehe...
audioguy
Good day sirs,
Have you experienced modifying your motorcycle electricity to high charge (from 12volts charging to 14volts)? Ive tried this modification with the help of mechanics in YOK shop located in Tondo Manila, with this, my left park light always end up busted. ( sometimes right park light). would it be nice to use LED in my park light?
thanks in advance :)
hi sir, just want to ask the exact add. of this YOK shop in tondo manila, and are they good in electrical...? whose the guy to look for if ever..? thanks :)
4playaz
hi sir, YOK shop is already closed. there are many shops out there that delivers the same skill. try FASTEK. along tayuman manila. infront of LTO tayuman. the shop is open around 2pm :)
