i believe its logic, rooster... why not you guys try this one by one;
1. inspect and tighten the front wheel nuts if needed
2. inspect and tighten the rear wheel nuts if needed
3. inspect and tighten the swing arm nuts if needed (need to take out the front sprocket cover)
4. check your tire pressure front and back (I'm using 29psi front ( 70/90 HF -918 Duro) and 33psi (80/90 HF -918 Duro)) Pls visit
http://www.durotires.com for more info. <-- my wobble problem settled after I did this all 4 steps.
5. inspect and tighten your handle if needed.
Try to do this first, before you decide to lower your fork, change to bigger disk, and etc. (my 2 cents)
p/s: now my bike back to normal, high speed riding in highway 170kmh (Malaysia speedometer) without problem.
