sparkaholic
HI i need help as i just got a spark and do not know what to modifiy
wow nice info complete from basic to final...thanks sirStage 1 Minor Mods
Exhaust System - Boost Acceleration & Power (AHM M1/CF)
RCDI - Boost Max RPM (BRT Hyperband/REXTOR V3)
Valve spring - need when changing RCDI (TK/CMS/FAITO)
Clutch Spring - Improve the Performance (FAITO ZERO)
Sprocket Combi - Acceleration (FAITO/SSS)
Stage 2 Basic Engine Mods
Camshaft - POWER & Acceleration (TURBO CAMS)
Ignition coil - Torque & Power (FAITO 7400)
Plug wire/Plug Cap (HTW) - to support ignition coil (FAITO Twin Core)
Iridium Spark Plug - Torque & Power (NGK/DENSO)
Clutch plate - Improve Performance (FAITO THUNDER)
Racing engine Bearing (FAG/FAITO)
Stage 3 Engine mods
Port and Polish
Crankshaft - Stroker (FAITO 3.5mm)
Bore kit - Engine displacement (Vi-xion57mm or Faito 60mm)
Carb & Jettings (Keihin/Mikuni 28mm)
Valve set (Faito)
Timing chain - use when changing crankshaft to stroker shaft (Faito)
Stage 4 Engine mods Final stage
Racing Gear set "Tranny" or Gearings (Faito)
Stage 1 Minor Mods
Stage 3 Engine mods
Port and Polish
Valve set (Faito)
(that's what I'm tryin to achieve right now.. )our motorcycle stock cdi has a revolution limit which will not allow our motorcycle to reach its maximum RPM. Racing cdi has no revolution limit thus giving our motorcycle more rpm and speed.i have already did some minor mods,but not actually the same brand mentioned,what does rcdi do or add to motorcycle performance?im a bit confused bro
That is just an option sir when talking about making your motorcycle faster. But stock block with rcdi will work just finewhy do we need to get vixion when changing rcdi?? just confused sir.. any good explanation, TIA..
Engine modification gives our motorcycles more speed and compression. The more higher the compression, the hotter the engine making our engine sag faster than normal. But the word it will destroy our engine is for the peeps who doesn't play it right, because a single mistake can cause you a lot of damage.some one told me that engine modification could destroy your motorcycle's engine.is it true?
that depends on how fast you want your MC to be sir.. give me an insight of your desired speedHI i need help as i just got a spark and do not know what to modifiy
ah i see.tnx.our motorcycle stock cdi has a revolution limit which will not allow our motorcycle to reach its maximum RPM. Racing cdi has no revolution limit thus giving our motorcycle more rpm and speed.
ok,it means.eventhough my engine is stock,i can use rcdi?our motorcycle stock cdi has a revolution limit which will not allow our motorcycle to reach its maximum RPM. Racing cdi has no revolution limit thus giving our motorcycle more rpm and speed.
