chrisniper19
ahahaha... mabubuking 3 days used lang....
.... icp mode pa... Up for KENTKART... awoooh....
.... icp mode pa... Up for KENTKART... awoooh....F/S Used RB Break Lever V2 Silver with minor scratchkxe sa loob ng houz aq ngpapark
800pair
By kr_rsniper at 2011-12-02
RFS:Biker Lever 6step Folded....
@ALL
UPDATE
USED ITEMS ko
Racingboy Fork Stabilizer V2 Silver 900
Racingboy v2 Bar-end (May gasgas) 200
OEM Mikuni 22mm w/manifold OFFER
OEM Clutch Lining 2010 Model 300
OEM Clutch Spring 100
OEM Valve Spring SOLD
OEM Air Filter Box 300
OEM Engine Bearing Set SOLD
OEM Stock 39T Rear Sprocket 100
OEM Stock Valve Set 1,000
OEM Stock Camshaft 1,500
OEM Stock oil filter cover 200
OEM Exhaust 1,500
OEM Tail Lights 2,000
OEM Front & Rear Mags w/Tires OFFER
B.New DID 428AD 130 Links 400 GENUINE
LHK Thailand Connecting Pin 2mm 850
PM na lang po pra sa Price or Best Offer pwede din po TRADE/SWAP items![]()
FAITO AVAILABLE PRODUCTS PRICELIST on LIMITED STOCKS
ALL ITEMS @ NEW PRICE
ALL BOLD LETTERS @ BIG DISCOUNTED PRICE...CALL OR TEXT FOR SURE BUYER...
Racing Gear Set (Tranny Set) = 9,000 "DISCOUNTED"
Crankshaft 3.5mm Jack up = 8,500 "DISCOUNTED"
Faito Infinity Block 60mm kit = 3,800 "DISCOUNTED"
Turbo Camshaft = 2,500 "DISCOUNTED"
S4-Evo Camshaft = 2,000 "DISCOUNTED"
Ignition Coil 7400 = 1,500 "DISCOUNTED"
Clutch Spring Zero = 600 "DISCOUNTED"
Engine Valve set Titanium = 2,600 "DISCOUNTED"
Engine Valve set = 1,600 "DISCOUNTED"
Racing Clutch Carrier Bushing = 200 "DISCOUNTED"
Racing Engine Bearing set = 1,800 "DISCOUNTED"
Clutch Plate Thunder (2010) = 2,100 "DISCOUNTED"
Clutch Plate Swift-Z = 900
Racing Disc Break Pad GOLD (2piston) = 1,200 "DISCOUNTED"
Racing Disc Break Pad PLATINUM (2piston) = 2,000 "DISCOUNTED"
H.I.D Mini Bulb (BLUE or WHITE) = 600 "DISCOUNTED"
Faito Special Gasket = 650
Faito Plug wire = 600 "DISCOUNTED"
Plug Cap = 330 "DISCOUNTED"
21T 4th gear = 1,600
Stock Connecting Rod Set = 2,400 "DISCOUNTED"
Gear Set 1st,2nd & 4th = 3,400 "DISCOUNTED"
Kr.r_sniper Location
1st step: go to maps.google.com
2nd step: enter this 14.630131,121.069044 on the search the map bar then enter...
CALL OR TEXT 09286144241 PLEASE RESPECT NO LOW BALLERS & BOGUS BUYERS..THANKS T135
NOTE: For Pick up only within Metro Manila,if outside Metro Manila Door to door delivery thru LBC or AP Cargo "Visayas & Mindanao only"...thanks
wala pa stocksir kr.r_sniper meron poh kyo fiato nah sproket nah 15 42t pah pm nlng poh tnx
parating pa lang
january 5 ang resume...close na ang port of bangkok...gusto ku ung seat.. magkano + na shiipping sa cebu?? id like to order
UP..
Salamat sa inyong dalawa
Salamat sa pagbili ng items at pagtitiwalaView attachment 12402 up kay angkul kent got my BRT na 2pcs, totoo pala pag december may discounts. a million tanx sa trusted seller
ahahahaha
