FAITO AVAILABLE PRODUCTS PRICELIST on LIMITED STOCKS
RFS: Need Funds...Thanks
ALL BOLD LETTERS with BLACK COLOR FONT @ BIG DISCOUNTED PRICE...CALL OR TEXT FOR SURE BUYER...
Racing Gear Set (Tranny Set) = 8,700 "DISCOUNTED"
Crankshaft 3.5mm Jack up = 8,000 for H/C & 7,000 for A/C "DISCOUNTED"
Faito Infinity Block 60mm kit = 3,400 "DISCOUNTED"
Turbo Camshaft = 2,500 "DISCOUNTED" (4pcs)
S4-Evo Camshaft = 2,000 "DISCOUNTED" (5pcs)
Ignition Coil 7400 = 1,500 "DISCOUNTED" (9pcs)
Clutch Spring Zero = 600 "DISCOUNTED" (12pcs)
Engine Valve set = 1,600 "DISCOUNTED" (4pcs)
Racing Clutch Carrier Bushing = 200 "DISCOUNTED" (3pcs)
Racing Engine Bearing set = 1,600 "DISCOUNTED"
Clutch Plate Thunder (2010) = 2,000 "DISCOUNTED" (4pcs)
Clutch Plate Swift-Z (06-09/2010) = 900 (12pcs for 2006-2009/5pcs 2010)
Racing Disc Break Pad GOLD (2piston) = 1,200 "DISCOUNTED" (5pcs)
Racing Disc Break Pad PLATINUM (2piston) = 2,000 "DISCOUNTED" (5pcs)
Faito Special Gasket = 650 (Free if you Buy Faito bore kit + Crankshaft)
Faito Plug wire = 600 "DISCOUNTED" (5pcs)
21T 4th gear = 1,600 (4pcs)
Stock Connecting Rod Set = 2,400 "DISCOUNTED" (10pcs)
Gear Set 1st,2nd & 4th = 3,400 "DISCOUNTED" (5pcs)
1st step: go to maps.google.com
2nd step: enter this 14.630131,121.069044 on the search the map bar then enter...
CALL OR TEXT 09286144241 PLEASE RESPECT NO LOW BALLERS & BOGUS BUYERS..THANKS T135
NOTE: For Pick up only within Metro Manila,if outside Metro Manila Door to door delivery thru LBC or AP Cargo "Visayas & Mindanao only"...thanks
