Hi rockies, The sound mainly in the middle of the engine....Mr.Rockies said:where it come on engine comp? right side,left side? listen where it come
My guess is your knocking noise is your exhaust valve tapping on the piston top; or the piston top slamming against the head; or valve clearance. I can be wrong. But I seldom am. ;ptraxxas-modifier said:heres my question to you gurus.
from my bike
1. If conrod is the cause of noise:
will it also have noise in high rpm?
2. this sounds appears "3 DAYS" after i removed 1mm from my 135cc block. will this be the cause of detonation or knocking?
the tick sound is gone in 3000and above rpm...
What worries me is....
my bikes credibility is tarnished due to that sound. HAHAHAHAHAHAHA!!!!
yestraxxas-modifier said:heres my question to you gurus.
from my bike
thanks for info bro.stroker said:My guess is your knocking noise is your exhaust valve tapping on the piston top; or the piston top slamming against the head; or valve clearance. I can be wrong. But I seldom am. ;ptraxxas-modifier said:heres my question to you gurus.
from my bike
