Paradox said:
bro stroker, if i reduce compression ratio, does also reduce bike performance? coz i noticed,
YZF R125 (124.66cc) SOHC
11.2 : 1 Maximum power 11.0 kW (15 PS) @ 9,000 rpm
T135 (134.4cc) SOHC
10.9 : 1 Maximum power 8.45kW (11.33 PS) 8500rpm
then how to increase performance, in the same time reduce compression Iratio? how they measure compression ratio using theory and pratical? can u gimme some calculation in engineering math?
u did mention, u build all racing part by urself from scratch.. do u special software? wat the machining portion tolerance spec do u use? Is it japan industrial standard (JIS) or ISO? thanks bro
I posted this formula on another thread:
stroker said:
where
b = cylinder bore (diameter)
s = piston stroke length
Vc = volume of the combustion chamber (including head gasket). This is the minimum volume of the space into which the fuel and air is compressed, prior to ignition. Because of the complex shape of this space, it usually is measured directly rather than calculated.
Yes, increasing compression ratio can help increase power. But there's only a limit. Many factors determined this limit. EG: the Volumetric Efficiency (VE in Short), how well your exhaust header is working, cam, valve size, port flow etc etc. Too much.
Simply use any CAD softwares that your CNC machinists support. I calculate, design and specs out the parts including dimensions, machining methodology, tolerances, material, treatment type/ specs etc etc.. The actual CAD and CNC done by the machinists of ours.
ISO, JIS??? Those are workshop practice standards right? I don't follow blindly on all that. The tolerances are set based on case-to-case basis. Especially automotive engineering, all the different parts have very differing requirements in terms of tolerances. Certain parts required closer tolerances. Typically 10-20 Microns. Certain parts, tolerances can be set looser to bring down production time and costs.
