motoJBracing
I'm in late here, I know, but there should be no tik tik tikking or tok tok tokking, ...tok tok tokking means bent valves if you keep at it and tik tik tikking means you need a tappet adjustment regardless of what cam your using. A tight 8 thou on the inlet and a tight 12 thou on the exhaust side works fine with very little valve train noise.
they had trouble selling them, wonder why
