LOW CAM ADVANCED
rem
Naka bore yan sir no? Ilangmm kaya???
hahaha.. the raiders on this ride runs on a minimum of 180cc displacement.. my snipers runing on 150cc displacement.. hehehehe
T_T runing on vixion bore kits and stock stroke.. hehehe
rpenera
I am very excited to try this cam, i already bought low cam, 28 mm carb, brt rcdi and r valve spring the only thing I need to buy is pipe before i start the mods and reach 6000km on my ODO. My bike is still under break in 1780 km on my ODO, my plan is to start the mods when my ODO reach 6000km. It’s so frustrating because I’m stock in 120kph top speed. Patience is a virtue ika nga :)
I know someone who uses this cam, before he's top speed reach 160 kph, he is using cms cam but when he change it to faito low cam he reaches 170kph.
According to him it has a small delay on low end power, but the mid and top is very powerful, it’s like driving a 2stroke racing machine, hold on tight when the rpm reaches mid going top. Hope that helps :)
aklan
Wow nice one. About mr. Rem sir i admire you snipee and your driving skills couse it holds your 150 max speed and you enjoying your ride even the raider 150 pass you by. nice one sir :)
aklan
Wow nice one. About mr. Rem sir i admire you snipee and your droving skills couse it holds your 150 max speed and you enjoying your ride even raid passes you by. nice one sir :)
Jessie Y
We have the same feeling about this cams. As I installed it yesterday on my Sniper......WOW after twisting the throttle just wait for 2 second and you can feel whats your looking for!!!!!
I only had Stock Carb what more when I install 27mm carb. All racing parts mod must be match with its other (I speak for my experience), not happy with my first MOD.
john-locke
Hi REM ,
i have questions about your video . what can i undestand with this video because you are all the time behind the others bikers and i saw others bikers drive very fast and all the time wait of you ?
Second : what is mid Rpm for you , and end rpm ? a number please .
Third : did you sell this part ?
rpenera
im using this type of cam. this cam requires modifications on ur flywheel. meaning it has a different tyming mark than ur stock tyming mark. it has instructions at the back on how to adjust. u also need to pocket ur pistons if your using stock pistons. or ur vixion. but faito infinity allready has pocketed pistons so wont need to pocket them. im using stock pistons now. with valve pockets 4mm deep. its not making tiktik sounds.
heres what happens if u dont pocket ir pistons. valves and pistons will hit. (bent valves/ or damaged pistons)
if u dont follow the modifications on ur flywheel ur mc would not run good. i tried using this on the standard mark on the tyming it would run. but it wont run well(power Deepi think thats what they call it).
heres what we did for this type of cam to make it run well on stock pistons
pistons............pockets 4mm
followed faito markings on tyming
used vixion valve springs to achieve higher rpm and remove valve floats.
other modes? hehehe.
Hi REM, i have a question? 4mm is your recommended valve pocket right? Can i pocket my piston to 5mm? because i am planning to remove the base gasket to increase compression. and the base gasket is almost 1mm correct me if im wrong. Need your expert advice please :)
One more thing, what is the maximum valve pocket for stock piston on sniper MX?
jay olikino
haven't installed my low cam yet. sir rem is it ok if i don't put pocket on my piston??? i'm using vixion kit with stock valves. i'm still using stock carb with 105 main jets and stock cdi.
