Juno
80-85km/h on 3rd gear **sir.. 105km/h?? on 3rd gear????... rpm limit for stock mx goes around 80-85.. doing 105 stock is impossible..
115-120 depends on the weight... you have 14/38 stock??.. woah!! my mx has 15/39 haha.. but already changd it, had an rcdi in it.. 28mm carb.. changed my sprocket set.. coz on stock.. 5th gear fels kinda off..dkp na test bro.
bro juno you are right on 3rd gear 80kph only.o105kph on 3rd gear impossiblesir.. 105km/h?? on 3rd gear????... rpm limit for stock mx goes around 80-85.. doing 105 stock is impossible..
yup.. coz i have my mx for almost 4 months na hehe had one a fw weks after it was ndorsed here in the phil.... most mods i have are all converted from sniper classic.. hhe oh btw the 2nd dition of RB rearset.. ithink will fit perectly to the mx..bro juno you are right on 3rd gear 80kph only.o105kph on 3rd gear impossible
pafs i will not say that i if i havent done it. twice i done it. and this is my first sniper. i dont fool around and that's my experience. yes, i have no proof in showing it to you but next time try it. now on my CLD racing pipe installed. 1st gear has been push to 45, 2nd gear has been push to 80 plus 3rd has been push 100. and this what amazed me is its only 3/4 throttle. better we forg0t what what i said. IMHO sir.sir.. 105km/h?? on 3rd gear????... rpm limit for stock mx goes around 80-85.. doing 105 stock is impossible..
bro nag try kana ng faito racing ignition coil sa mx mo? im planning to buy and install it to my sniper mxsir.. 105km/h?? on 3rd gear????... rpm limit for stock mx goes around 80-85.. doing 105 stock is impossible..
I used to replace cylinder & rings and do all over again when i found my Break-In was a failure; in this way i believe, could save me a dime in every liter of fuel i burn, too soon maintenance that can be frequent later on. This model made me so happy after only a few hundreds of kilometers of series of acceleration & deceleration, and made it to 60~63 kms/liter consumption with my daily farm chores. A very good Bike.WHAT?! 120-130 all stock??.. weh??? for real??. mines 100 km/h already at RPM limit on stock cdi... how can a bike with a 24mm carb and a stock cdi do that???.. haha damn then min is sloow i think
bro motorhead, are u from philippines?just wonderingI used to replace cylinder & rings and do all over again when i found my Break-In was a failure; in this way i believe, could save me a dime in every liter of fuel i burn, too soon maintenance that can be frequent later on. This model made me so happy after only a few hundreds of kilometers of series of acceleration & deceleration, and made it to 60~63 kms/liter consumption with my daily farm chores. A very good Bike.
yupz, i'm from Bogo City, Cebu brod Yongx2bro motorhead, are u from philippines?just wondering![]()
a retired USAFi tot u were somewhere else coz nag nosebleed na me sa imong mga english.. gege![]()
a retired aircraft tech. bro Yongx2, 379 air expeditionary wingi tot u were somewhere else coz nag nosebleed na me sa imong mga english.. gege![]()
bigatin ka pala bro.i have a friend from bogo also.her name is ailyna retired USAF
bigatin sa langis at maruruming grasa, parang Surf. i believe most of the ppl in this place knows me.bigatin ka pala bro.i have a friend from bogo also.her name is ailyn
Hi sir, your friend and I have the same problem with our smx... I already told the mechanic about it, he said it is normal for smx to gets hot easily, he told me that a certain level of heat will activate the fan/pump the coolant to the radiator... can any tell us if it is normal for sniper mx engine gets hot to fast.. for some time the engine is hotter than the inner pipe ( weeeeeeeeewwww)..My friends MX got problem... His sniper MX engine gets hot to fast.... we both use same engine oil... but his engine gets hot easily.. need help....
Thanks.....
bro where did you buy your cld pipe?pafs i will not say that i if i havent done it. twice i done it. and this is my first sniper. i dont fool around and that's my experience. yes, i have no proof in showing it to you but next time try it. now on my CLD racing pipe installed. 1st gear has been push to 45, 2nd gear has been push to 80 plus 3rd has been push 100. and this what amazed me is its only 3/4 throttle. better we forg0t what what i said. IMHO sir.
