My Purchases
Stockbore
@P@simuno - Stock Crank bolt
@speedmaniac - Vixion valve spring
@P@simuno - Stock Water pump -
@eni pagulayan - Stock bore
@kimredbull - Faito 60mm
@traxxas-modifier - 2 valve seal
@bosschx - stockbore -
@traxxas-modifier - Cam bolt - February 22, 2013
@traxxas-modifier Tensionaire - February 22, 3013
@bhek_21 - 28mm Keihin repair kit - February 27, 2013
@kimredbull - head and block works fz - February 28, 2013
@speedmaniac - Uma cam - March 4, 2013
@speedmaniac - Brt hyperband - March 19, 2013
@traxxas-modifier - Tappet screw 4 pieces - March 20, 2013
@kimredbull - Stock valves 2 sets - March 20, 2013
@bhek_21 - Keihin racing carb - March 30, 2013
@bhek_21 - Brt dualband - March 30, 2013
@speedmaniac - RB alloy rim rear - March 31, 2013
@kimredbull - Hi-speed valve - April 8, 2013
@traxxas-modifier - Timing chain tensionair - April 8, 2013
@speedmaniac - 28mm keihin - April 10, 2013
@speedmaniac - RB hand grip alloy - April 10, 2013
@speedmaniac - Namban Pipe - April 15, 2013
@kimredbull - 8 pieces Tuning Jets - April 15, 2013
@speedmaniac - BRT HYPERBAND CDI - April 18, 2013
@speedmaniac - UMA clutch plate - April 24, 2013
@speedmaniac - 28mm keihin - April 28, 2013
@speedmaniac - Nob1 proliner - April28, 2013
@speedmaniac - BRT dualband - April 28, 2013
@speedmaniac - Uma airfilter 2pcs - May 8 2013
@speedmaniac - V4 Lever Racingboy - May 8, 2013
@speedmaniac - V2 Balancer Racingboy - May 8, 2013
@speedmaniac - Rubber grip racingboy - May 8, 2013
@speedmaniac - Cruise Control 2pcs. - May 16, 2013
@traxxas-modifier - kawahara 66mm block - June 1 2013
@kimredbull - hispeed racing clutch lining - June 1 2013
@kimredbull - brt dualband powermax mio mx - June 1 2013
@speedmaniac - Uma clutch spring - June 1 2013
@speedmaniac -Rb cruise control - June 1 2013
@speedmaniac - RB rear break arm -June 1 2013
@speedmaniac - Rb rubber grip - June 1 2013
takomi
mine is
set of tires from jt triumph=SHINKO
seat cover from caloocan =MS SUIT
handle grip from caloocan =RACING BOY
and plan to buy some on IR EVENT,.:D
sniper71
mine.......leovince pipe,orig cdi (no limiter),oil filter (washable),disc lock w/ alarm...from master krr...
milu
I ordered the following from sir traxxas-modifier:
6speed tranny mx
aeroblade mirror
protec racing carspeed
NGK iridium
He will ship it when he gets the aeroblade at hand.
Happy motoring everyone...
