My Purchases
Stockbore
@P@simuno - Stock Crank bolt
@speedmaniac - Vixion valve spring
@P@simuno - Stock Water pump -
@eni pagulayan - Stock bore
@kimredbull - Faito 60mm
@traxxas-modifier - 2 valve seal
@bosschx - stockbore -
@traxxas-modifier - Cam bolt - February 22, 2013
@traxxas-modifier Tensionaire - February 22, 3013
@bhek_21 - 28mm Keihin repair kit - February 27, 2013
@kimredbull - head and block works fz - February 28, 2013
@speedmaniac - Uma cam - March 4, 2013
@speedmaniac - Brt hyperband - March 19, 2012
Stockbore
@traxxas-modifier - Tappet screw 4 pieces - March 20, 2012
@kimredbull - Stock valves 2 sets - March 20, 2012
Stockbore
@speedmaniac - Brt hyperband - March 19, 2013
@traxxas-modifier - Tappet screw 4 pieces - March 20, 2013
@kimredbull - Stock valves 2 sets - March 20, 2013
@bhek_21 - Keihin racing carb - March 30, 2013
@bhek_21 - Brt dualband - March 30, 2013
@speedmaniac - RB alloy rim rear - March 31, 2013
mac kevin
mikuni carb vm26, cms vs, k1 black cam= @traxxas-modifier
brt powermax hyperband=@speedmaniac (2 year ago na sa kabilang channel pa)
planning to buy protec ignation coil or car speed but Im so worry of what other said... brt cdi paired with racing protec ignation coil or car speed is not compatible, great chances that my brt cdi may get busted.. pls clarify masters, if it is hearsay or true ..
Stockbore
@turbulence is using protec ignition coil with ground strap and brt dualband. everything works fine. I wonder why because i think ignition coil has nothing to do with cdi
mac kevin
mikuni vm26 purchased from sir admin traxxas, so ito stock settings nya, kung same tayo carb, d kakasya ang 102 alam ko yun, i dont know baka ibang series sa vm26 yan, liit na nga butas two below 150, 102 pa kaya, baka binutasan mo ng drill kit yang 102 mo, jejeje, ok naman performance nya, tipid masyado... compared sa stock. tested na jettings na po ito according to sir admin traxxas, 20pj 150mj original mikuni vm26 on stock engine
Stockbore
have you compared the 150 jets to keihin 150 jets?
