New T135 Carburetor
krux
clydelisboa said:
what do you mean by (slide-type) Carb? is it like the keihin or oko 26mm carb?
keihin and oko is an example of the normal slide carbs
the normal slide carbs has a direct cable from the throttle to the carbs slide. so when you twist the throttle it lifts the slide and needle letting the gas and air through....
the other type has a rubber diaphragm at the top of the slide. and has the
butterfly throttle. and the cable is attached to the butterfly . when you twist the throttle the butterfly opens letting air in. at same time it create vacuum at the top of the rubber diaphragm and lifts the slide and needle letting the gas through....
clydelisboa
so it means slide carbs perform better than our rejetted stock carb with tps? Im planning to buy 26mm keihin or oko carb. which of the two performs better keihin or oko?
mick xxxx
When I looked into buying an OKO before, the manufacturer (in China) told me I needed a 28 mm. Was that wrong?
The reason I was put off getting one (I have an X1R btw) was that although the OKO comes with manual choke, there is no provision for the 2 connections (don't know what they do) which talk to the CDI.
You guys are obviously using these carburettors, so what do you do about that?
If I knew the answer to this I'd order one tomorrow at about $35, as I'm facing buying a new standard carb' at about $80-100 because I used Gasohol (Thailand).
Thanks for any information you can give me.
if you are not familiar in modifying carb and jettings
i suggest to buy the 2011 25mm yamaha mikuni carb
its plug and play for x1r/t135
TPS is builtin in the carb of 2011
mick xxxx
Sorry, but I'm confused.
My story - I've had the X1R for 2 years and I liked it a lot but it never ran as smoothly as the Spark I had before and at times it was really rough, albeit still fast.
Recently it got worse and I took it to the shop. They said they'd cleaned the carb' but it was worse.
They said it was because I'd used Gasohol (probably true) and that I needed a new carb', but they couldn't get them as they don't stock the X1R in Thailand any more.
So I arrived on your Forum.
The part I'm confused about is that I just took the carb' off, because I had to either way and to see what I'd got and it's a round slide Mikuni (about 22-23 mm I think) - probably you knew that.
Is the 25 mm carb' you're selling definitely going to be better?
Looking in the bowl everything looks very clean to me.
I'll get the jets cleaned and try it again I suppose.
Is it possible that it's not the carb' at all do you think?
Could a faulty CDI cause the uneven running on heavy acceleration?
Thanks for any advice.
xpmove10
does the carb of 2008 nouvo z bs26 with tps is 100% fit to our sniper??
Yes it fits perfectly into our bike, but the problem said. The different jettings, need help if what is the size of main jet and pilot jet compatible to 150cc vixion bore kit
odie_perry44
so that means that the new sniper mx has more power and speed than the old one becauswe of the carb? i experienced it when we drove for almost 800km it only took me 3 full tak of gasoline plus a heavy backride plus twisting and uphill roads....i only achieved 115kph top speed on a straight road but most of the time my group was cruising at 100kph...very fuel efficient and also has speed...btw my MX is all stock i only changed the front tire to 80/80 mizzle maxxpro for good grip and handling the rest is all stock.i hope my experience helps...ride safe guys
lpsnipie_67
wow! your mc is really fuel economy 266 km. / 4 liters ... I'm surprised!
carltomy
Do you think 90x80 tire will fit on stock mx?
Lester Chua
UP!!!:shag:
JoyT
Hi guys newbie here.....juz wandering,how can i order the bs25 kit with manifold n tps?
bhek_21
Guys, I just got my repossessed yamaha smx.. I brought it to yamaha 3s shop and found out that the carb was replaced with the old sniper carb. The mechanic told me that this carb (piston type) is way better than the current carb (diaphragm type) of smx. Is this true?
