skin last2weeks lng ako nagbago ng set hahhahah pag nka200 na ako birit birit din ahhahahahala ganun pa din..hehehe..break in pa din..matagal tagal pa to..
hahahahha siguro hahahhaha minsan nung nag break-in ako ng 62 200km plng done na ako kse minsan 45mins idle ako tpos linis sparkplug pagkatps tpos before magikot 30 mins idle.... tpos ndi q binebaby 80 to 100 agad nilalaro laro q aun ok na ewan q lng nowpwede kaya gamitan ng tread mill pag ng break in ng motor?kakainip e..![]()
40km pa lang daw as of now e..kakatawag ko lang..660km pa..di pede sakin ng 200..mga 500 ko na pabibigyan para sure..alanganin un piston e..4mm taas sa deck height..nka re angle na nka spacer pa,nka pocket pa,nka dagdag pa timing chain n isa...bka magloko pag npwersaskin last2weeks lng ako nagbago ng set hahhahah pag nka200 na ako birit birit din ahhahahah
alanganin ako e..hindi kasi normal na piston..dami pa ginawa..pati kapatid ko at brkda/rider ngreklamo,npkatigas dw sipaan..di kagaya dti na pede bagsak bagsak langhahahahha siguro hahahhaha minsan nung nag break-in ako ng 62 200km plng done na ako kse minsan 45mins idle ako tpos linis sparkplug pagkatps tpos before magikot 30 mins idle.... tpos ndi q binebaby 80 to 100 agad nilalaro laro q aun ok na ewan q lng now
salamat sa sagot paps![]()
break in ng block?sakin 300km tapos yung susunod sa 700km na..parang sobra naman kung 50km..ilang kms ba before first change oil kapag break-in?
yung sa youtube, 50kms lang daw?
Na-upload ni helerrr noong Ene 24, 2010How to breakin an engine using motoman hard break in style.For newly purchased motorcycle/car or newly installed cylinder block or rebore block, This is an example of engine hard breakin procedure as per motoman mototuneusa break in method.step1: warmup the engine for about 5-10minutes on idlestep2: go outside your city and do the quick acceleration and decelerationstep3: use all your gearsstep4: rev it hard but dont let the throttle steady on the same speed, always play with your throttlestep5: After 50kms of hardbreakin, change oil and change the oil filter (a must)step6: hardbreakin again for the next 500kmsstep7: change oil after 250kmsstep8: hardbreakin againstep9:changeoil and change oilfilterstep10: hardbreakinstep11:changeoil after 1000kms and change oil filterstep12: enjoy your fast bike!!!Lastly Do this at your own risk!
Got this from youtube..
baka minola gamit sa 1st 50km...sa mio dati 200 first ko then 500 kasunod..pero never ako ng hard break in ng bore up..sabagay di pa naman kasi ako nagkakaro ng brand new na motor...sa cage puro hard break in ako pag naka 100km na..digmaan na..sarap sa exit sa Bocaue tapos exit sa San Fernando..mahal lang tollgate hehehenakakapagtaka nga eh.. 50 kms lang then change oil na.
tnx paps.. bili nalang ako bukas.. may idea ka ba kung magkano speedo cable na mio??mio paps..mas maiksi..at mas maganda..
