Status
Not open for further replies.
macoolet
:rolleyes: anong mas best na oil para sa vixion block?
repsol 15-50, repsol 20-50 & elf 10-60
naka engine cover at bellyfan ako.kaya lagi ang andar ng radiator fan:oops:
gusto ko sanang kahit papano mapalamig ng oil yung engine.
sakin gamit ko lang dati shell vsx hehhe pang digmaan ko na yan..500km lang change oil na
sniperyaz
Na-upload ni helerrr noong Ene 24, 2010​
How to breakin an engine using motoman hard break in style.​
For newly purchased motorcycle/car or newly installed cylinder block or rebore block, This is an example of engine hard breakin procedure as per motoman mototuneusa break in method.​
step1: warmup the engine for about 5-10minutes on idle​
step2: go outside your city and do the quick acceleration and deceleration​
step3: use all your gears​
step4: rev it hard but dont let the throttle steady on the same speed, always play with your throttle​
step5: After 50kms of hardbreakin, change oil and change the oil filter (a must)​
step6: hardbreakin again for the next 500kms​
step7: change oil after 250kms​
step8: hardbreakin again​
step9:changeoil and change oilfilter​
step10: hardbreakin​
step11:changeoil after 1000kms and change oil filter​
step12: enjoy your fast bike!!!​
Lastly Do this at your own risk!​
Got this from youtube..
hard break in kasi kaya 50 kms palit agad madami agad rebaba yan paps
sniperyaz
semi synthetic ang pinaka maximum na langis para sa atin kasi wet sump yung lining natin kung synthetic ang gamit natin sa mc natin ubos agad yung lining natin
macoolet
excuse me sr anu po magandang brad ng swingarm pwdeng kabit po sa sniper tska po pipe tnx po :D
amp how much pa po pala ung koso digital speedometer for sniper salamat ping madame
swing arm: DBS,yamaha,TDR,racing boy,banana type,aprilia inverted,pro arm
pipe: DBS,yy pang,namban,4n,hgm,ecs,replica pro,musashi,ahm,cld,r9,yoshimura
koso digital: ask mo na lang mga seller sa for sale threads
Lester Chua
kse boss tinanggal na mung compression release sa cams natin so mhirap tlga sipaan... ang nagi2ng problem na lng is matigas sipaan and malakas ang back pressure.... kpag malakas pa ang back pressure sa P&P hinhabol un sir hehehhe
Lester Chua
macoolet kse boss tinanggal na mung compression release sa cams natin so mhirap tlga sipaan... ang nagi2ng problem na lng is matigas sipaan and malakas ang back pressure.... kpag malakas pa ang back pressure sa P&P hinhabol un sir hehehhe
Lester Chua
40km pa lang daw as of now e..kakatawag ko lang..660km pa..di pede sakin ng 200..mga 500 ko na pabibigyan para sure..alanganin un piston e..4mm taas sa deck height..nka re angle na nka spacer pa,nka pocket pa,nka dagdag pa timing chain n isa...bka magloko pag npwersa
sabagay hehehhe skn kse dami sikreto hahahahha bsta mtatapos din yan papz
Lester Chua
nakakapagtaka nga eh.. 50 kms lang then change oil na.
boss noted naman dun na hard breakin right???? kaya siguro gsto nya 50 kms kse po my mga rebaba yan para mhugasan lng ung engine natin and the next is 500km db sir kse wla ng rebaba so pde na hard breakin ulit nsa rider naman po yan kung gsto na nya ichange oil sir ..... pero ms ok kung binabanlawan natin ung langis natin para sa mga rebaba and besides sir kapag hard breakin mabilis umitim ung langis sir hehehehhe
Lester Chua
i go for elf..... natry mo naba ung gulf or ptt challenger???
Lester Chua
feedback nman po sa faito turbo camshaft mga master.. may fake ba?
im not sure kung my fake ah cguro naman wla kse new palng ang faito d2 satin.... pero nkabili na ako ng faito titanium valves and block ok naman matibay naman sir.....
Status
