rhoitol
kaya dapat pag modified na engine..alaga sa maintenance..Not bad for vixion spring..yan talaga disadvantage ng modified engine..shorter lifespan of engine parts..
Hind pa nga sir. Meron na po kaya spare parts para sa SMX?Saan pokaya makakabili?Meron po ba sa Caloocan? Balak ko po kasi bilin yung OEM din.Salamat po sa reply!Kung hindi kapa po nagpapalet ng clutch lining simula nung binile niyo 100% upod na clutch lining mo...kahit wag na po palitan clutch spring kung hindi kah naman racing rasing..hehe
meron poh..or kung gusto mo pwede yung tmx oem lining,,,parehas lang ng clutch lining ang mx at r-edition..Hind pa nga sir. Meron na po kaya spare parts para sa SMX?Saan pokaya makakabili?Meron po ba sa Caloocan? Balak ko po kasi bilin yung OEM din.Salamat po sa reply!
Ayos pala sir ah!Pwede din pala OEM Lining ng TMXmeron poh..or kung gusto mo pwede yung tmx oem lining,,,parehas lang ng clutch lining ang mx at r-edition..
!Kala ko mahihirapan ako mag hanap. pero sir ok lang kaya yun?sensya na sir dami ko tanong.
Sabe ng mga master dito parehas lang daw..hindi ko pah kasi natatry pero mas maganda baklasin mo na yung mx mo then dala kah ng sample lining sa honda dealer..tsaka advantage ng honda lining di hamak na mas mura kesa sa yamaha..Ayos pala sir ah!Pwede din pala OEM Lining ng TMX![]()
Mga kat135 tanong ko lang po, ilang PSI po sa compression gauge ang ideal for daily use ng naka 62mm na bore up kit?![]()
Hi guy, i'm from VN, and i have a question about Sniper MX's swing arm. My bike crashes and it's swing arm is bended because it's structure is very weak, so i have to buy a new one.
My question is...every time (unlucky) i crash, do I have to buy a new swing arm ??? Do you have any solution for this ???
Tks you very much Sir, i found this pic on VN's wedside, so maybe i'll do itnope its just a badluck if you crash that your swingarm will disalligned.
you can add steel tube brackets on your original swingarm to prevent
bending like that but still i suggest to ride safe![]()
, does it look ok ?
Nyahaha..he is spamsafe..fyi..Tks you very much Sir, i found this pic on VN's wedside, so maybe i'll do it, does it look ok ?
P/s: Your bike looks like Spamsafe's bike on youtube, i watch a lot of video of him
Di ko pa po napacheck sir @traxxas-modifier, pero hirap yong uma electric starter ko na walang kahiraphirap dati sa 57mm ko.anong compression reading ng sayo?
sakin sir kahit stock starter umaandar yung uma 62 ko, with matching big valve head 19/22. baka mataas lift ng cams moDi ko pa po napacheck sir @traxxas-modifier, pero hirap yong uma electric starter ko na walang kahiraphirap dati sa 57mm ko.
Sabi kasi ng iba pacheck ko yong compression ko baka sobrang high comp na kaya gusto ko lang malaman ano safe na compression
PSI ng 62mm para pag pinacheck ko papadagdag nalang akong base gasket pag sobrang taas ng compression.
Anong compression po ba na pwedeng pang araw araw gamit mc ko na di sasabog makina kahit matagalang byahe?![]()
Ganon ba sir, anong compression ng mc nyo sir? Anong cam gamit nyo?sakin sir kahit stock starter umaandar yung uma 62 ko, with matching big valve head 19/22. baka mataas lift ng cams mo
Ganun na nga lang siguro gagawin ko sir. Plano ko na din po pala mag palit na ng clutch spring. para may konti lakas pag arangkadaSabe ng mga master dito parehas lang daw..hindi ko pah kasi natatry pero mas maganda baklasin mo na yung mx mo then dala kah ng sample lining sa honda dealer..tsaka advantage ng honda lining di hamak na mas mura kesa sa yamaha..
. Lagi po kasi ako may angkas. Yung LHK po sana bibilin ko kasi hindi daw po sya ganun katigas pag piga ng clutch. Mukhang ok pang everyday use. ano sa tingin nyo sir? Salamat po!Baka may tumutugtug na MC mo paps kaya sumasayaw pag high RPM na ... joke lang bro ...Mga bro patulong lang sumasayaw na kasi ang motor ko at 120kph high rpm. Anu kaya posibleng cause nun? Salamat sa sasagot.
Nakalhk spring ako date..better than stock..Ganun na nga lang siguro gagawin ko sir. Plano ko na din po pala mag palit na ng clutch spring. para may konti lakas pag arangkada. Lagi po kasi ako may angkas. Yung LHK po sana bibilin ko kasi hindi daw po sya ganun katigas pag piga ng clutch. Mukhang ok pang everyday use. ano sa tingin nyo sir? Salamat po!
salamat sa reply sir. Sirbaka may idea po kayo saan maganda bumili ng LHK Clutch Spring sa caloocan. Sure po na Original. May nabasa po kasi ako may mga fake po nito. may napagtanongan po ako 120 pesos lang parang sobra mura. Baka fake po yun hindi ko binili.Nakalhk spring ako date..better than stock..
Sir Nakabili na ako LHK, bago na po pala yung brand name nya L-Power Race naNakalhk spring ako date..better than stock..
. Ilan po ba maganda ilagay pag manual clutch
? 2pcs lang po ba or 4 pcs spring na ? Ilan po ba nilagay nyo dati sa sniper nyo?Salamat po!
