pno sir pumupugak? back fire po ba???help naman po. nagpalit kasi ako ng open pipe, pero pag sumasagad na takbo every gear pumupugak siya. dahil po ba ito sa limiter? o sa carb siya?.. anu kaya maganda po gawin.. TIA
You will know if its limiter or carb, If it feels that you are running out of gas then is your carb. You have to change jettings. If you did not feel this, then its your limiter.help naman po. nagpalit kasi ako ng open pipe, pero pag sumasagad na takbo every gear pumupugak siya. dahil po ba ito sa limiter? o sa carb siya?.. anu kaya maganda po gawin.. TIA
ganito siya sir, pag nasa low gear ako, tpos pag naabot na max speed ng gear parang nagpapashift na siya. limiter ba yun sir? kase noong stock pipe lang ako di ko naman nararamdaman yun.You will know if its limiter or carb, If it feels that you are running out of gas then is your carb. You have to change jettings. If you did not feel this, then its your limiter.
may backfire din minsan sir.pno sir pumupugak? back fire po ba???
It's possible that the oil has dried up. Just replace the oil seal and add proper amount of oil.Good morning po mga Masters, ask ko lang ano po kaya posibleng sira ng front shocks ko, may tumutunog kasi kapag umaandar na sya parang kumakatok, intact naman sya kaya lang yung dust seal medyo parang angat na konti parang may yupi kaya may angat? Ano pa po kaya palitin dun maliban sa dust seal? tnx po n God bless!
Then you have problem with air fuel mixture and indeed your limiter is kicking in. The problem with open pipe is you can reach max rpm that your CDI has. This is the reason why your limiter kicks in while it's not present on stock pipe.may backfire din minsan sir.
Not sure for the brand but if dont have proper tools, you better get this done by a mechanic. Less hustle, effort and headache. Oil is P80. I forgot the price of Oil seal but you wont spend more than P150 for the oil seal.Thank you Sir @Paladin , madali lang ba magpalit (magtanggal) nung oil seal at dust seal as in DIY? Ano magandang oil brand para sa shock natin? Salamat ng marami papz![]()
Thank you sir, tinignan ko nga yung service manual, wala me nung mga tools na gamit.hehe! Dalin ko na nga lang sa 3s shop ng yamaha, P150 good for two na yun na oil seals? Yung kayang dust seal mga magkano per piece? tiaNot sure for the brand but if dont have proper tools, you better get this done by a mechanic. Less hustle, effort and headache. Oil is P80. I forgot the price of Oil seal but you wont spend more than P150 for the oil seal.
Thanks again sir. Need to see a good mechanic asap.Then you have problem with air fuel mixture and indeed your limiter is kicking in. The problem with open pipe is you can reach max rpm that your CDI has. This is the reason why your limiter kicks in while it's not present on stock pipe.
If you go to 3S shop, you will spend more. Expect a Casa price. I'm referring to repair shops. Don't worry, they can do it same quality with 3s can do but with lower price.Thank you sir, tinignan ko nga yung service manual, wala me nung mga tools na gamit.hehe! Dalin ko na nga lang sa 3s shop ng yamaha, P150 good for two na yun na oil seals? Yung kayang dust seal mga magkano per piece? tia
Thank you sir, mga magkano ba kapag sa 3s nagpagawa ng shocks?tnx poIf you go to 3S shop, you will spend more. Expect a Casa price. I'm referring to repair shops. Don't worry, they can do it same quality with 3s can do but with lower price.
That I'm not sure. Expect a casa price.Thank you sir, mga magkano ba kapag sa 3s nagpagawa ng shocks?tnx po
Okay thank you sir, ano ba sa palagay nyo sir maganda aftermarket na front fork tube sa sniper classic para sabay ko na din pagpalit ng oil seal , dust seal at fork oil. tiaThat I'm not sure. Expect a casa price.
Trusty and 7 speed I think...Okay thank you sir, ano ba sa palagay nyo sir maganda aftermarket na front fork tube sa sniper classic para sabay ko na din pagpalit ng oil seal , dust seal at fork oil. tia
