JapSpeed
mga master normal lng ba na mg iba tunog ng engine if mg valve spring? stock cam lng po... hindi naman tik2x sound. at hindi naman tutunog kng idle lng... jvt valve spring gamit ko..
suplado010
Ok lang po bah ikutin yung sa rear brake system na racing boy yung kinakabitan ng brake fluid reservoir?Nakaturu kasi sa baba yung hose e..
papam78
Gudpm po! Sir, balak ko po mg big block pero stock heads p din po. Ano po b max size n mganda ilagay? X1r po byk ko. Tsaka nid po b palitan carb nya? Tnx po.
papam78
Last question mga sir, s 62mm po b n steel bore. Ok lng po b un s stock head paired with big carb? For everyday use lang po pero sna noticeable po un dagdag n lakas compared s stock.
jangbest
steel bore paps? mag crome bore ka hindi advisable ang steel bore sa daily use ...
pwede din naman stock head sa 62mm pero dapat naka port ang head mo diba @snipersolem gamit nya 62 naka port
Julio25
gud pm mga master pano po ba malaman kung naka align ang manibela ng sniper mx???pakiramdam ko parang naka paling sa kanan manibela nung naikabit na..:help::help:
Ptr.Jun
...What do you mean "Naka Port ang Head"
I'm planning to install 61mm bore with Stock Head...
Ano ang i modify sa Head?... valve,Valve Spring,at Cams?
Ptr.Jun
To veteran Sniper owners...
With 61mm Chrome bore, R Cdi, STOCK HEAD... Is that ok for everyday use and Long Distance?
kikaipitoy
gas consumption with your set up? please share us bro..:thumbsup::thumbsup::thumbsup:
My set: 62mm Bore, Vixion VS, Faito Turbo Cam, 28mm Carb, Mushroom Type Air Filter, Protec Ignition Coil, BRT Dualband CDI, LHK clutch springs, HGM GP Type Big Elbow,19/22 BV, 15/42 sprocket combi....
Before: between 40-48km per Liter
Now: Between 30-34km per liter :confused::confused::confused:
I think that's the down side of having a fast bike, but I never mind...IMHO if you don't like high consumption MC just stay stock...;););)
