pwede naman idol.. l8 rply pcncy naOk lang po bah ikutin yung sa rear brake system na racing boy yung kinakabitan ng brake fluid reservoir?Nakaturu kasi sa baba yung hose e..
hanggang 59mm ang stock head, sa carb mas maganda kung big carb, pero pwede din stock carb rejet langGudpm po! Sir, balak ko po mg big block pero stock heads p din po. Ano po b max size n mganda ilagay? X1r po byk ko. Tsaka nid po b palitan carb nya? Tnx po.
ano kaya gas consumption ng 59mm block. as in plug and go lang... with stock carb nka rejet with stock cam, rcdi, and valve springhanggang 59mm ang stock head, sa carb mas maganda kung big carb, pero pwede din stock carb rejet lang
steel bore paps? mag crome bore ka hindi advisable ang steel bore sa daily use ...Last question mga sir, s 62mm po b n steel bore. Ok lng po b un s stock head paired with big carb? For everyday use lang po pero sna noticeable po un dagdag n lakas compared s stock.
pwede din naman stock head sa 62mm pero dapat naka port ang head mo diba @snipersolem gamit nya 62 naka port
...What do you mean "Naka Port ang Head"steel bore paps? mag crome bore ka hindi advisable ang steel bore sa daily use ...
Using my 62mm with stock head for a few months..OK naman kaso mas ramdam mo talaga lakas sa big valves..just my two centsTo veteran Sniper owners...
With 61mm Chrome bore, R Cdi, STOCK HEAD... Is that ok for everyday use and Long Distance?
gas consumption with your set up? please share us bro..Using my 62mm with stock head for a few months..OK naman kaso mas ramdam mo talaga lakas sa big valves..just my two cents
My set: 62mm Bore, Vixion VS, Faito Turbo Cam, 28mm Carb, Mushroom Type Air Filter, Protec Ignition Coil, BRT Dualband CDI, LHK clutch springs, HGM GP Type Big Elbow,19/22 BV, 15/42 sprocket combi....gas consumption with your set up? please share us bro..![]()
Thanks! Nice TipUsing my 62mm with stock head for a few months..OK naman kaso mas ramdam mo talaga lakas sa big valves..just my two cents
