open pipe :/
PLDC
i used open pipe..
when i used it i have big consume of gas what em i supose to do?
i tune my carb already please help
what is the stock jettng of stock carb i use stock carb
main and pilot what is the stock size
stock jets ko
mj 103.5
pj 20
sabi ito daw palit ko edi lalong mlkas sa gas
main jet 107.5
pilot jet 22.5
peakabu
try mo muna...dpende rn kasi yn sa driving style mo eh...bka nman galit k sa throttle kya malakas sa gas...
sabat
undleaded
bro, ask q lng nung unleaded gmit muh? if Caltex GOLD madali tlgang maubos! dont know y?
base kz s experience q before!
patune muh s 3s mc muh, kabisado nila Sniper ntn!
stock sniper q, pero open pipe din aq ! DBS.
d nmn matakaw s gas! konti lng diff. nya if i use stock pipe!
note! V-POWER p gmit q. ( mataas ang octane= madaling sunugin)
HTH!! ride safe bro!!
Paladin
Ganun talaga pag big elbow malakas sa gas. I used namban on stock sniper, lakas talaga sa gas. Kahit anong gas pa ikarga, malakas sa consumption talaga. Bumababa kasi ang compression kapag naka open pipe lalo na pag big elbow. Ang resulta lumalakas sa gas. Kung i-tune naman ang carb, magkakaron naman ng backfire. Ganyan ang experience ko before.
bryanmabaet
HGM BIG ELBOW PO SAKIN>. KAKAPALAGAY q lang. kaso one wik biglang nagbago ung tunog. humina humatak bakit po kea? anu po ba dpat q gawin help pls.. anu din po ba dpat na gas q?? new sniper q po e bago lang aq nag ka sniper
glen_01
baka may singaw, kaya nagbago tunog, saka nag iba hatak, check mo lang sir. pero pag big elbow tapos stock engine lakas ata talaga sa gas.
bryanmabaet
nung binile q ung big elbo lumakas hatak po nya e. tapos mga one wik lang nagbago tunog, humina humatak... wala naman po xang singaw :(
Steve
Palit ka ng Gas. then fill up with Blaze. Kasi minsan, sa klase ng gasoline mo, bigla nalang mag bago tono ng motor mo.
bryanmabaet
pwede po ba unleded??? ask ndin po sir... anu po bang magandang brand at tatak pwede q ilagay sakanya na cams at clachspring po ba tawag dun.
mhektheone
kung matakaw sagas ang motor subukan mo tubig malay mo umandar..joke....
bka naman bossing mataas masyado ang minor mo....o kulang sa change oil kasi pag matagal mag change oil mahina ang motor natin birit tayo ng birit short distance lang ang mararating kaya malakas sa gas..try mo tune up and change oil bro tingnan natin kung malakas parin sa gas..kasi pwede rin sa valve mo ang problema kaya ganyan....sana maka tulong
Paladin
I agree with glen, there may be a leak. Check the pipe installation if its properly installed. Better apply high temp silicone gasket maker (If with extra budget). Secondly, adjust the air/fuel mixture of of your carb since from stock to open pipe makes the air/fuel mixture change. Thus, makes a decrease on your bikes performance.
bryanmabaet
tokay po change oil q agad at tune up./.... thx po
bryanmabaet
panu po adjust ung air fuel mixture dre? :(
opoi stock to open pipe xa e, big elbo pa po
Paladin
Try po nyo ikutin yung fuel. Taasan nyo lang po ng konti para magmatch sa settings. Paki consult nalang po sa manual kung saan sa dalawang iikutin kung ano yung sa air at kung ano yung sa fuel (di ko kasi kabisado). Better punta po kayo sa 3S shop. Kabisado po nila yung sniper.
bryanmabaet
okay po salamat ^_^
