Sir may i ask what happens if my mc will experience valve float due to overrevv? I newly instal BRT hyperband on my SMX. TIAwhen you change your CDI you must also change thevalve spring to prevent valve float when overrevv..
it will kiss...for short "tungkod" if you over rev...Sir may i ask what happens if my mc will experience valve float due to overrevv? I newly instal BRT hyperband on my SMX. TIA
Tnx a lot ice...! I needed that cause one of brod here experiences some sound on over revving his smx. We have the same rcdi used.it will kiss...for short "tungkod" if you over rev...
for example:
stock cdi 12,000rpm + stock valve spring 12,000rpm both are compatible
Racing cdi 15,000rpm + stock valve spring 12,000rpm = valve float if over rev
*stock valve spring can't take the 15,000rpm of your Racing cdi..
racing cdi and after market valve spring goes hand in hand bro...
savvy?
np bro... better change ur stock valve spring bro...Tnx a lot ice...! I needed that cause one of brod here experiences some sound on over revving his smx. We have the same rcdi used.
Tnxs bro Ice! Ride safe always!np bro... better change ur stock valve spring bro...
its better to be safe than sorry at all..goodtimes! keep safe!!
Tnxs vhadz..! suggestion well taken. Ill just also share ur recommendation to my bros. thanks for the tips bro.@renr400,
ur friends bike is still ok, if still runs it means its healthy when its stop its busted, f valve springs breaks ur engine stops( base on experience )... i dont know if its still runs when u still push through,, dont wait that a problem well emerge act quickly..
here in our place, we have a friend with smx, we have remove his stock valve&clucth springs,and have install rsprings & rcdi but his on stock pipe, maybe next month were gonna install pipe, cams then remove comp assy,, soooon maybe..![]()
nope!!do you condiser NOB1 as an open pipe?
5th racing posture@maized 30
ur brother is right, f your using Rcdi change ur valvesprings as what john_carlo have said & papa ice,,
this msg goes to you aswell renR400...
rvalve springs is a must when ur using rcdi..
take this note;
basic steps of performance level of motorcycle
1st open pipe,
2nd racing cdi -when install take it easy dont over rev..
3rd racing valvesprings - when install rev freely, no worries..
4th racing clutchsprings..
how about ahm gold or silver?nope!!
