RX4439
Regrinded? Means u lay ur stock cam profile?Regrinded Cams is better. my 1st camprofile cams looks like the malossi power cams. Ive got a new regrinded cams better than my first.![]()
Did your 1st and 2nd re-grinded cams are your stock cams? Or they are already aftermarket cams? I would agree that profiled cams is a way better..Regrinded Cams is better. my 1st camprofile cams looks like the malossi power cams. Ive got a new regrinded cams better than my first.![]()
Did your 1st and 2nd re-grinded cams are your stock cams? Or they are already aftermarket cams? I would agree that profiled cams is a way better..![]()
Thanks for the info bro.. By the way, did you bring your stock cams to camprofile in mandaluyong area?i used stock cams bro. havent used aftermarket cams.
Oh my mistake..no bro, that's in QC..
I'm also near JETRON racing shop.. if you're familiar with both of them..thanks sir.Camshaft is responsible for the opening and lift timing of your intake and exhaust valves.. Please correct me masters..
Advantage: Better performance
Disadvantage: You will get addicted in modification..![]()
Both of it sir but you still need to consider other aspects and not just focus only on racing camshaft to obtain what you are looking for..thanks sir.
but what exactly is the increase in the performance?
acceleration and top speed-wise?
TIA![]()
well sir, my current plans in speeding up my mc isBoth of it sir but you still need to consider other aspects and not just focus only on racing camshaft to obtain what you are looking for..![]()
just be a disciplined rider bro even if you installed performance parts..well sir, my current plans in speeding up my mc is
just to install a NOB1 tribold and changing the sprocket ratio of my mc.
too afraid to go further,
faster bike=shorter rider life
just got curious about the racing cams.
but IF ever i add racing cams to my my list,
will it have a significant increase in performance?
like, from 130ts to 140ts?
woah..just be a disciplined rider bro even if you installed performance parts..
but take note: "Great power.. Great responsibility.."
As I have said, it will add up but you still need to consider some parts to compliment with it..
I know someone here only installed RCDI.. you know what's his bike's speed? 2nd gear 120kph..![]()
isn't that dangerous for our engines?
ask sir @traxxas-modifier browho knows what is the best VALVE CLEARNCE for KAHAWATA K1 BLACK CAMS installed on Stock Bore sniper MX.
To Rowan - Chill bro.
You use the Faito Lowcam Advance, can i know about the marking that u use when installing this Cam? Should be std marking or advance?
Btw, What HKholic said was true, he (xclickclickx) refer to his own personal cam collector.
P/S - There a lots of cam out there, CMS, YY Pang, MDS, Popeye, GT Racing, Ride It, ETC.
