kalau racing cam = high cam? ade x racing cam = low cam? contoh tokahi (tkh) racing cam = high cam?Low cam pick power rpm
= Low ke medium
High cam pick power rpm
= Medium ke high
X fhm bro tnya perkalau racing cam = high cam? ade x racing cam = low cam? contoh tokahi (tkh) racing cam = high cam?
Racing cam after market ade lowcam dan highcam, beza dua ni degree cam tu tk silap saya .. Lowcam contoh cms t1 or cms tr, dan high cam cms t2 dan cms t3kalau racing cam = high cam? ade x racing cam = low cam? contoh tokahi (tkh) racing cam = high cam?
Klu pki high cam mcm Cam UMA R1, lepas ke utk engine stended?Nk sedap lyn town guna low cam nk lyn highway guna high cam. Low cam cpt dpt pick power tp top mati. High cam lambat dpt pick power tp top speed idup. Klu nk set spoket kecik2 guna low cam
Btoi bro, tapi masa2 akan datang cadang nk tukar block 62..tu dh alang2 beli uma 28mm.. carb tu perlu setting n jetting jgk ke utk engine stended buat masa skrg?pada sy utk moto std uma 24 dah cukup..uma 28mm terlalu besar pd sy..
Yg tu saya tk pasti, kena tnye pomen sbb tk pnah try.. Utk carb tu rasa cm tk sesuai 28mm sbb besar sngt.. Saya tk pnah try utk stndrd tp klau utk spec fz pnah .. Tggu otai2 dlm ni rply dkt awakklu pakai high cam cms t2 lepas ke untuk engine stended?
thanks bro, besar sngt ke carb tu utk stended..boleh bro share skit spec fz bro..lg detail lg bagus.. moto v2 sy dh dekat 5 tahun pakai..dh rs lemau..sbb tu bru skrg nk start modi..klu x keberatan..mntk bro share resepi skit.Yg tu saya tk pasti, kena tnye pomen sbb tk pnah try.. Utk carb tu rasa cm tk sesuai 28mm sbb besar sngt.. Saya tk pnah try utk stndrd tp klau utk spec fz pnah .. Tggu otai2 dlm ni rply dkt awak
Salam,Salam, maaf sy bru nk brjinak2 dlm dunia modi lc135. Harap otai2 dlm ni boleh beri tnjuk ajar. Moto sy dh modi tp sy tk brapa reti nk tune carb sy dan carb sy semput2, timing dan angin tk stable. Bila koyak hbis dia trsedak dan delay, bila koyak slow2 dia nak mati.
Spec modi yg sy dh buat.
Blok Espada 62mm
Piston Taikom 62mm
High Cam Uma
Valve Spring Racing CMS
Cdi Oren Thailand
Carb Taikom powerjet 28mm (spec mcm uma)
Ekzos stndrd CjIpoh 30mm
Jd disini sy nk minta nasihat dan pendapat otai2 yg ada utk bantu sy tune carb sy. Size Mj dan Pj apa yg sy kena pakai.
saya pkai spec 62 carb nsr set mj110 pj35 plug perang terang...Salam, maaf sy bru nk brjinak2 dlm dunia modi lc135. Harap otai2 dlm ni boleh beri tnjuk ajar. Moto sy dh modi tp sy tk brapa reti nk tune carb sy dan carb sy semput2, timing dan angin tk stable. Bila koyak hbis dia trsedak dan delay, bila koyak slow2 dia nak mati.
Blok Espada 62mm
Piston Taikom 62mm
High Cam Uma
Cdi Oren Thailand
XBhya ke spec 62 guna mj saiz 110..sy pon blok saiz 60 dah rebore jd 61mm pakai 120 pj 35.risau bos..baik lbh ckt mj tu.saya pkai spec 62 carb nsr set mj110 pj35 plug perang terang...
baik bos sy dh up mj120 pj35 plug jd perang gelap nk ke hitam dh.. beza dye top meningkat la bos.. tq utk nsihat 2 sngt membantuXBhya ke spec 62 guna mj saiz 110..sy pon blok saiz 60 dah rebore jd 61mm pakai 120 pj 35.risau bos..baik lbh ckt mj tu.
kalau carb bunyi kuat 2 maknenye ezos kurang lawas ye.. bkn sbb pj kecik.. sbb moto sy kalau hi rpm bnyi carb perit je.. pkai ezos uma spec 65Kalau plug cantik dah ok la tu.. Ejos kurang lawas tu..
