did you do it yourself sir?yes.. just repainted..
did you do it yourself sir?[/qu
i can do the repaint by my self but for the quality i run to the paint shop.. he he he
ipapalo mo nalang yan sa mga mi kompyansa paps.. yan din ginawa ko.. successfull din naman..sir napapagawa p po b kaya yung mags d nmn sya oblong kaya lang nagkaron ng tama yung gilid yung pinakalabi nya umangat..
As far as I know, it should be heated first then hydraulic press.. this is the technique of the machine shop that I've inquired before.. I don't know if it has an adverse effect on our mags material due to heat but it's quite more reliable than hammering it..ipapalo mo nalang yan sa mga mi kompyansa paps.. yan din ginawa ko.. successfull din naman..
This is just my opinion..
how's the performance paps?As far as I know, it should be heated first then hydraulic press.. this is the technique of the machine shop that I've inquired before.. I don't know if it has an adverse effect on our mags material due to heat but it's quite more reliable than hammering it..This is just my opinion..
By the way.. I like the 15-44 combi..![]()
they'll torch it first to soften the part that needs to be aligned..you don't need hammer in your case.. they can use vice grips..sir napapagawa p po b kaya yung mags d nmn sya oblong kaya lang nagkaron ng tama yung gilid yung pinakalabi nya umangat..
just like what the manong lolo did to my bengkong mags before
thanks!nice pipe sir.. home i meet your mx to hear the sound personally..
what is your engine set-up sir?what brand of Valve spring are the best? pls. help..
city driving or long rides?i like to know what is your fuel consumption after making mods to your sniper mx? mine got average 36 km/liter. always maximizing every gear and 100 - 120 kph on open road.
city driving or long rides?![]()
36 km/liter? w/ that mods? wow. isn't that big?both. city driving and long rides. got rcdi,valvespring, rcam, cluctch spring.
only RCDI clutch spring and a little re-jetting the CARB.what is your engine set-up sir?
Maybe sir you should try Vixion valve spring since it's yamaha OEM parts for 150cc engine displacement..only RCDI clutch spring and a little re-jetting the CARB.
