pedro hunyo29
yeah.. that' my plan too since i finally experience the differences between the sprocket combi..This is my current sprocket combination..Don't you wanna try 14/41 or 15/42?
Since you are already using RCDI, I think you should change your valve spring to stiffer one.. Changing clutch spring is not enough.. You also have to re-jet your carb or replace it with a bigger one and change your camshaft.. then test the result..![]()
go ahead and let us know what will happen.
I'm targeting to get a vixion valve spring and BRT cdi..
