Sniper Mx Modifications
saintDave
good day.share2x. hre my modes.. SPS head 20/22, valve clearance in-0.08mm. ex-0.10mm, bore xray ceramic forge peston 62mm, carb keihin 28mm PJ-42 LJ-112, uma clutch spring, high speed valve spring, sprocket combi 14-38... valve tip no pud2x nah.. i like it.
chrisz
anyone here tried using racing gear with our sniper mx? can you suggest of any brand what gears are needed to be replace and what size of teeth to be used?TIA papz!
vav_mugen524
What is the best sprocket combi sprocket for my Sniper Mx?. My set is uma 62mm, stockhead ported, dual band cdi and pe 28mm. Tire is 120x70R and 90x80F. My weight is 95kg. My present sprocket combi is 14x36. Thanks!
dan08
Newbie here, planning to modify my smx. What's your opinion on jvt59mm, jvt cams stage 1 and hi speed stage pipe. Use for daily use and for touring mode. Ride safe to all.
SPEED RACER
my new sniper mx all stock reach 110kph
with some engine tweak & sprocket change 140kph
engine:
vixion valve spring
uma racing cdi
remove base gasket
kalkal stock pipe
14-42 combi sprocket
and some lighting modes
dan08
engine:
vixion valve spring
uma racing cdi
remove base gasket
kalkal stock pipe
what size of tire you're using paps?.
jhay
any suggestion with my bike, 4months old,, nka rear seat nd hgm pipe npo xa tpos stock pa lhat sa engine ,,
what changes should be made ?
ESOJ de GUZMAN JR
for basic upgrade for additional power using your stock bore. just replace your cam to ''uma,lhk,kawahara,faito'' just use stage 1. and also replace your valve spring. (para isang bukasan ng head) and replace also your cdi to racing cdi. and if u want stock carb just rejet to mj-117.5. and replace also your sprocket. 80kgs + you can use 14-40,41,42 or 15-42. good luck.
t135_user
Hi! Newbie here, just got my mx some engine mods, spec-v camshafts, mtrt valve springs, rcdi, removed base gasket, and did port and polish... Do i need to replace or do something to my stock carb? It seems that its short of gas... Thanks.
Hi mga papa...what is the best sprocket combi of this set
UMA SUPERHEAD + UMA 62mm bore + 28mm carb UMA
currently i'm using 14x42 which is not good for the above set.
