haen said:
TIP #8
Use a 4 leg RELAY (BOSCH is recommended, PART CODE BOSCH - 0 332 019 453 ), use this to power ur CDI and make that LAZY HORN TO WORK BETTER !!
(see pics attached)
installation on my BIKE :
(see pics attached)
FEEL THE DIFFERENCE !
1. Better ignition because the current is pure = better performance
2. No more power loss when u turn on the head lamp..
3. Cheap trick to increase ignition performance
UPDATE :
4. Your main lamp now is brighter too
INSTALLATION PROCEDURE :
Leg number 30 goes directly to BATTERY'S POSITIVE TERMINAL , use thick cable and clamp, and fuse house complete with the fuse, 10 A will do...
Leg number 87 goes to CDI (cut the brown cable from the harness in the middle and connect it to the relay)
Leg number 85 goes to main switch (the other END of the brown cable that goes to the CDI female socket)..
Leg number 86 goes to GROUND, use cable terminal and screw it anywhere on the chassis (i screwed it at the CDI's bracket bolt)..
TIPS : buy a relay socket to make it easier and appropriate cable terminals (2 female small terminal (goes to the original socket), 1 small cable terminal (goes to the terminal from the original socket, after u pull it out of course by using small minus screwdriver and press softly the small part at the socket terminal), 8 large female terminal (4 for the relay's legs on the socket,2 for cable connection,2 for spares), 2 male large terminal...
I did apply this tip#8 today.
creating a new wire dedicated for CDI with relay.
i need to have my cdi power wire (color brown) to be separated from
my main wire because ive got lots of gadgets accessories
installed in my bike.
yes it does improve the acceleration
because
you will supply the cdi the required amount of current needed by it.
by default if youve got no additional accesories installed, then the stock
brown wire to power your cdi is just fine...
but for me, ive got tons of accesories and lights installed.
then its better to have a dedicated wire.
