SOME PROVEN TIPS and TRICKS for T135
bro n guys..i have change everything to stock mode..but now i have change it again..is it ok if i just done trick no #3 but didnt mod my stock airfilter??
Gagarinz
Hello guys,
Its long time not in contention in this forum..hehe its quite busy rite now.
So, a had a lot of modification on my ride compare to previous reply on page 8.
Rite now, my ride spec (additional) are as follows:
Cdi: BRT Smart Click = BTDC 31 degree, 12.5k rpm
Valve spring = Convert to racing
Bore = 58.5mm
CAM = Ride-it (low-CAM)
Valve clearance = 0.15 in, 0.15 out
Carb = Mikuni Flatslide 24mm (open air w/o filter) :?
So, need suggestion from the Expertice here.. for current condition;
1. Is it BTDC setting is correct if I turn to 31deg instead of bigger deg?
2. Is the valve clearance good enough or in-correct if I tend to have a top better speed? My machine also is quite noisy with this setting.
3. My pipe (ABM) sometimes create unstable sound and sometime it suddently gave "pom" like small explosion.
Does anybody could help me since I'm so naive in this modification field?
:oops: :oops: :oops:
haen
changing CDI only doesn't mean u'll get more top speed bro areif, lots of factor affecting top speed, like TDC setting, valve clearance, TPS, etc..
low cam is good at low speed but high speed is a bit hard to go....
high cam which can lift the tappered higher n long enough...this is equal to more power at high speed but low speed is decrease...
rite bro haen??
haen
The "Porting and Polishing" Myth
It is popularly held that enlarging the ports to the maximum possible size and applying a mirror finish is what porting is. However that is not so. Some ports may be enlarged to their maximum possible size (in keeping with the highest level of aerodynamic efficiency) but those engines are highly developed very high speed units where the actual size of the ports has become a restriction. Often the size of the port is reduced to increase power. A mirror finish of the port does not provide the increase that intuition would suggest. In fact, within intake systems, the surface is usually deliberately textured to a degree of uniform roughness to encourage fuel deposited on the port walls to evaporate quickly. A rough surface on selected areas of the port may also alter flow by energizing the boundary layer, which can alter the flow path noticeably, possibly increasing flow. This is similar to what the dimples on a golf ball do. Flow bench testing shows that the difference between a mirror finished intake port and a rough textured port is typically less than 1%. The difference between a smooth to the touch port and an optically mirrored surface is not measurable by ordinary means. Exhaust ports may be smooth finished because of the dry gas flow and in the interest of minimizing exhaust by-product build-up. A 300 - 400 Grit finish followed by a light buff is generally accepted to be representative of a near optimal finish for exhaust gas ports.
The reason that polished ports are not advantageous from a flow standpoint is that at the interface between the metal wall and the air, the air speed is ZERO (see boundary layer and laminar flow). This is due to the wetting action of the air and indeed all fluids. The first layer of molecules adheres to the wall and does not move significantly. The rest of the flow field must shear past which develops a velocity profile (or gradient) across the duct. In order for surface roughness to impact flow appreciably, the high spots must be high enough to protrude into the faster moving air toward the center. Only a very rough surface does this.
SOURCE : WIKIPEDIA
yenza88
traxxas-modifier said:
i was able to talk a the mechanic of one of the member hawkeye135
and he uses his t135 in circuit racing...
he installed 32mm carb
and got no airfilter..
i tried his bike, and its really fast!!!
They also removed the decomp assembly already tip#2
and true to what haen is saying yes removing decompression
assembly or they call it locally as "Compression Release" will really
help because the mechanics explanation is, for some reason
there are times that this decomp assembly stockedup and wont work
the way it should be thus releasing the compression....
and loose power..
soon i will do that... and will show pics...
on how to do it.
really great help your info haen!!!
bro,can u show the pics?
haen
NEW TIPS :
USE THIS FILTER INSTEAD OF YOUR STOCK OIL FILTER, IT IMPROVES THE OIL FLOW SIGNIFICANTLY, AND CAN BE WASHED AND REUSED UP TO THREE TIMES OIL CHANGE...
haen
costs usd 12 for the filter, it was a super filter for our t135 --> EDIT : due to prevent misunderstanding, this price is for one carton (20 pcs)
wow another good tip bro haen.
sell it bro!
i guess thats much better than K&N oil filter for our bike :)
k&n oil filter is way expensive :)
haen
@traxxas : thanks bro, personally after using this filter i sense my engine a bit cool now, and those who want the super oil filter better group order to save shipping cost, for USD 16 can ship 20 filters to one address.
