Sprocket combinations.
Status
Not open for further replies.
arechin
miobikerboys said:
but anywayz, heres somethin to take note off:
Those who have big tyres who plan to go back to stock, its a terrible idea, too much load on the engine! If you've got a bigger rear, it helps alot. I went back to stock today and top speed was terrible! Only 120km/hr!!
Go back to stock means takin ur tyre size down a notch or two.
i think i've been through ur situation mio..
dats y now im juz can maintain to 120kmh..
its been like riding a bicycle..huhu~
before changed to my stock tyre,im using FKR n its wide but then,its already bald coz of im always burn it..:wink: then i've change to stock tyres Vee Rubber coz of no money to bought it new one..i tot i was my sprocket coz at the same time i've change my sprocket too to 16/41..
then change it to my last setup 14/36..its still same..my bike juz can go around 120-130kmh..n so far ryte now was 140..
bloh
MioBikerBoyz said:
To all of you who wants to know what sprocket combinations to use for your T135, I have done a little research and after constant modifying and spending and taking hell from my wife, I have found these combinations:
Sprocket combinations for faster accelaration (top speed will suffer):
1) 13 - 36 = 2.76 Fastest accelation combination
2) 14 - 36 = 2.57 Acceleration is still fast but with an added speed
3) 15 - 36 = 2.40 Fastest possible combination for fast accelaration
Average accelaration and top speed:
1) 13 - 35 = 2.69 Good accelaration, acceptable top speed
2) 14 - 35 = 2.50 Equal accelaration and top speed
3) 15 - 35 = 2.33 Better top speed
Top speed combination (Accelaration will suffer):
1) 13 - 34 = 2.61 Fast
2) 14 - 34 = 2.42 Faster
3) 15 - 34 = 2.26 Fastest
Front Sprocket/Rear sprocket = The smaller value the faster speed and vise versa.
So you can reduce from the stock rear 39T to a smaller sprocket in order to reach your desired top speeds, but remember, these combinations will affect alot of quick acceleration, good luck!
MBB.
just change to sprocket 15 - 36....very satisfied with this comb....engine run very smooth.....acceleration not bad....currently top speed 100kmp, will try it at highway.......
bloh
rudduan said:
is the 3rd gear will be so long then shift to 4th gear with that combination???
yes sir....
previous i used stock sprocket....15-39 its make the engine loud when in hi rev....
dude_pare01
with that set up...the fourth gear power may not be enough to push the bike...i still have the stock gearing and i can speed to 115 to 120 kmh max at fourth gear...
arechin
haha..
me too..
tot dat while in 3rd gear,i reach 110 then if shift to 4th gear where it supposed to be a bomb,but..
huhu..its juz 120..
bloh
arechin said:
haha..
me too..
huhu..its juz 120..
glad to hear that......another good point is when you stopping and never use brake...its like not dragging at all.....which I like it very much.....
and when it stop....chaging gear so smooth and it will not drag also.....very statisfied...... :D
but....will it doing good for angine?? any one have prblem with this comb so far??
Status
