Pls dont make your gearbox suffer...try 15/40 or 15/42charge said:Thanks for the advice justkir. Is it possible to install 125Z gearbox on 135LC? How much is the custom gearbox cost?
My main purpose of having more gears is to make each gears shorter while maintaining top speed. It is very annoying when I run on my weekly course in Teluk Bahang.
The maximum speed I can go is only 95kph on the only longest straight (less than 100m). On other straight roads (not even 50m in length), usually I'll full throttle 2nd gear up to 75kph and then accelerate a bit more with 3rd gear to 80+kph. Then it will reach a tight corner, where I have to brake until 40kph only. The whole course is like having corners after corners for 8 minutes.
It is great to have 2nd gear max out at 60+ kph and 3rd gear max out at 100kph. I'll get a lot more acceleration and less frustration on unmatched gears.
Really appreciate if you guys can provide more info gearbox.![]()
youve got pics bro?kirana said:just buy the KITTY 1/2/3/4gear set bro
??? Come on man... Raider is the easiest to modify in tems of pick up,mid range and topspeed... If you can't find powerful Raider there where you at, I assure that it is a different story here in Manila... We have a stock bore, w/ minor modification Raider if you guys want to give it a try, you're very welcome... Give me Raider anyday... BTW, you can get hold of Raider stock/racing parts here real...goff_d_p said:Sorry to disapoint you, but the Raider isn't that great of a bike. Thats my opion. it's harder to find modifcations parts to make the bike really stand out in your own way.
Pick-up till top is fast than stock gearbox same as we put 5gearbox from Vixion or 150fzikirana said:picture hheeeem will do it next time. the good thing is better pick up all the way till 4rd gear,no waiting on 4rd gear for top speed. recoment to change 1/2/4 gear only.. me only 4rd gear.
