told yahtried 14/42 on my sniper mx and all is i can say is wow as in wow! 0-100kmh takes few seconds only and even with backride, still acceleration is ok. Much better than 15/42. Top end speed on full throttle is only 110-116kmh on my speedo normal sitting position. Maybe i will try to bend my back a little bit next time to reach 120kmh, hehehehehee.
guys,wow ganda ng tips nato.. me natutunan ako ^^ tnx sa TIPS Sir
i up my stock bore to 58mm shark racing,CMS racing cam,tyre 70-90 same infront n back,sprocket 36-15,carb is standard but mainjet 115,pilot 22.5, but can go over 160 not 180..so what is the best sprocket to going to 180,190,200.... please help me..im a newbiebro follow the tables of sprocket combination
listed on page 1.
pay particular to gear ratio
feel your bike.
if you feel that your bike accelerates fast BUT low topspeed
then select the next lower gear ratio
vice versa...
feel your bike bro.
follow the tables listed.
Understand what gear ratio means.
gear ratio of 2.6 means
2.6 turns of engine is equal to one revolution of tire/wheel.
in bicycle,
you need to pedal 2.6 turns to make 1 wheel revolution of tire/wheel.
once you understand that, you will know whats best for your motorcycle.
So follow the gear ratio ONE AT A TIME.
.. in malaysia we using RM is means RINGGIT MALAYSIA for our money currency ... i spend about RM 250 ... maybe this month i got to buy RCDI n upgrade my valve spring to racing valve spring ... cause i dont want a cut-off.. its will make your engine trouble,spoil,inferno,ok. which spark plug do you use in your moto? i heard about denso iridium ngk iridium, denso racing iridium spark plugs, theres even ngk-cpr9 which they said is longer than our stock spark plugs ngk-cpr8. does these spark plugs really make the differrence? will it improve acceleration or speed whatsoever. there are videos also that this iridium plugs are used for motoGP and according to riders, gives good engine response, quicker acceleration, bla bla bla. would you mind sharing what you know about this?i stay in town so maybe the highway is not so long .. over long just 10km but not feeling like to smile on 200cc,hehe...my motorcycle can over at 160 only...huh.. in malaysia we using RM is means RINGGIT MALAYSIA for our money currency ... i spend about RM 250 ... maybe this month i got to buy RCDI n upgrade my valve spring to racing valve spring ... cause i dont want a cut-off.. its will make your engine trouble,spoil,inferno,
@ traxxas-modifier, Sir would this be applicable on a Old Yamaha sniper? Stock bore?tried 14/42 on my sniper mx and all is i can say is wow as in wow! 0-100kmh takes few seconds only and even with backride, still acceleration is ok. Much better than 15/42. Top end speed on full throttle is only 110-116kmh on my speedo normal sitting position. Maybe i will try to bend my back a little bit next time to reach 120kmh, hehehehehee.
