T135 Sprocket Table Combination Part 2
mayb im sound a little bit wrong...but
if u are using bigger tyre than stock...the recommended setting is UP the ratio rite???
ok try this...instead of gaining the ratio..try lower the ratio...
eg,
i am using front 80/90 rear 110/70 in all stock setup...but i use 15-37
i can maintain 150kmhin highway..
if all stock setting..just the tyre is bigger than stock
try 15-38
this is happening to me...but remember...one bike is different than other..even if it the same yamaha t135...
enjoy....
axon
guys consider i already upgrade my 4t gear to 21/ 24
i'm moslty travel with long distance min. 50km to 100+km
do i need to to change my sprocket 15/ 39?
what will be the result assuming if i use 15 37(maka arangkada pa kaya ako???) after i upgrade gear set, tire size is 80x80f 100x80r?
TIA..suggestion please...ride safe to all
Nuan Lei Ran
Alin mas ok sa acceleration yong di ma-stress ang engine kahit di na ang top speed. . . 15/42 or 16/42 (all stock, rider 58-60kg )?????
j_caldeojr
i tried 15/42 so far the accelaration was good but when you reach 90kph - Up the engine vibrate was to strong. I think 15/42 is the best on the city driving.
So far as of now im using stock combi for city driving i can reach 100kph without strong vibration on the engine.
But im trying to put 15/40 maybe next year..
Hope it can help sir.
Ride Safe
allen_afro
mga papa pa pm nman po anu mgndang sprocket combi sa 90/80 80/80 tires? 60kgs po ako. di ko po alam anu pinakamagandang combi dito tsaka anu magiging epekto kumpara sa stock settings
noi
paps kng stock lng motor mu better 2 use 15/40.... tested nd proven....... uphill nd downhill tamang tama lng nd matipid pa sa gas.......
ambokz
15/42 with 110/70 and 80/80 all stock,sabi wla daw dulo ang combi na yan,pru satisfied nman ako,pru want to try 15/40 combi,ok kaya?
kr.r_sniper
Chrome Front Sprocket : 15
Chrome Rear Sprocket : 40
Chain : 428-120
Chrome Chain(15T + 40T + 428-120L)
ask lng mga paps kung ok ung ganito chain & sprocket set?stock po lhat pti gulong...patulong nman mga MASTER=))anu kaya topspeed nito?
