T135 technical/modification discussion (ENGLISH ONLY)
m00nraker
can any one know how much this following item???
a:) clutch pressure plate
b:) clutch housing
and were can you recommend me the best 3s shop in manila... thank you sir's hope someone read this
marcusfilter
b:) clutch housing
Clutch Pressure Plate - 2S6–E6351–00 try to call 6457760
Yamaha Marikina they have a good mechanic there, and they have parts as well.
just tell them that you are SOS ...
re the price, I am not sure, or better yet PM traxx he might have the parts you needed.
m00nraker
b:) clutch housing
Yamaha Marikina OK din ang mechanic don, and they have parts as well.
sabihin mo lang SOS ka...
yung price, di ko sure, or better yet PM mo si traxx baka meron sya
thank you sir... can i have the complete address sir or the nearest landmark there?? i dont were it is eh .. hehehe thanks pres
marcusfilter
you know shell pugon, right....just make a U-turn then you are headed to cubao...street after McDonalds turn right, that's Tuazon...just go straight....after 200meters you will see Yamaha Marikina almost in front of ST KTV bar.
ride safe
m00nraker
ride safe
thanks for d info sir gud luck to me na lang tom hehe
mingomz
Guys,
For those who are using x1R kit, Have you experienced ticking sounds on your disc brake?... When running around 10KPH.
I have experienced this before and it went away, but now it's coming back again...
the sound seems to come from the rotor.
Just want to know your whereabouts
thanks!
interceptor
mingomz said:
Guys,
thanks!
ask sir linjun and sir rampy directly po...
or better yet ask your supplier...
raider125jeigh
interceptor said:
mingomz said:
Guys,
thanks!
mingo ask J2cab hahahaha....
mingomz
It seems to be okay. I will check again later if there would be signs that it warped.
HAHA, let's not talk about backrides anymore. I might get killed.
raider125jeigh
Did you go to J2CAB for them to check it?
mingomz
Not yet maybe this friday, I am on VTO here in the office this fridat then rest day on sat and sun. I will have time to tinker my sniper.
I also consulted marcus about this, we'll check for further problems that might cause the sound on the rotor..
BOSS_CHO29
@moon...i think you can find fork oil at any motorcycle shops...if your near caloocan you, can buy it at exceed, tres hermanas exact, cyclemar ect...there are lots of brand but i recommend repsol fork oil...
ride safe...
marcusfilter
@MR, Motul fork oil is the one I am using, Good performance.
I guess Maxima has Fork Oil has well, you can checl motorworld or the shops posted above this post.
ride safe
