T135 technical/modification discussion (ENGLISH ONLY)
raider125jeigh
marcusfilter said:
@MR, Motul fork oil is the one I am using, Good performance.
I guess Maxima has Fork Oil has well, you can checl motorworld or the shops posted above this post.
ride safe
Yup did is very good pre....
i believe it is much expensive than repsol am i right?
base on thread i read.... 231ML per fork......
marcusfilter
did? are you drunk? ha ha ha...
regarding the amount to be filled, IMHO there's no specified volume of fork oil to be filled on, If you have a different shock cover there will be a different amount as well.
How hard to replace a fork oil...Super hard..ha ha ha..because you have to check it afterwards have a test ride then if that wont satisfy you, open and change the volume...
If I were you, change it yourself cause if you will have it replace by a MC shop you wont get the best performance, cause mostly are one time filling only...
ride safe
raider125jeigh
ride safe
LOLZ ..PRE im sorry my bad im just frustrated..you know why....hehehe..
the 231ML for stock forks..what i have is 7 speed ..i just used TUTI hahaha,,i cannot buy fork oil near our location nyahahaha... this is not recommended guys... but for the meantime hehehe..
marcusfilter
the thing I learned from my bike is if you take good care of her...she will take care of you as well.
I treated my bike better than my....ha ha ha...I bathed her(Eleonor) at least once a week if ever she'll get wet and dirty.
No cheap oil or replacement material...My ODO reads at almost 30k..most of if from gruelling ride and so far she didnt make me "pahiya" ha ha ha
ride safe
raider125jeigh
marcusfilter said:
I still have Motul fork oil...You know where to get it...ha ha ha
thats a good news hahaha...
i believe i wont be able to get that unles i join the aritao - baguio ride...hmmMmmm[schild=1 fontcolor=000000 shadowcolor=C0C0C0 shieldshadow=1]Bribery [/schild]
marcusfilter
ha ha ha...No you can have it...That's One good thing about SOS...It's sharing and helping each other...
Does anyone gave a Pirelli tyre to you? ha ha ha
raider125jeigh
ride safe
hmpf!!! bad.... if ever your sniper get pregnant...hahaha..give me one ,,lolz...
Pre do you know someone who is using 7 speed fork that used front fender... using 90 x 80 front tires? i tried to used (yoshimura)bracket or clamp but the clamp is so big that the tires touches the fender...
EZRA uses fibercrafts front fender and posh bracket..but the tires are 80 x 80 i wonder if 90 x 80 works ...
marcusfilter
ha ha ha...if ever...I will give you one...
Jason has the same shock cover i guess...he's using a customized cable tie...ha ha ha..modified for sniper only
BOSS_CHO29
ouch ...was that me? hahaha
thats why i love you paps...mwah mwah mwah.... :D
BOSS_CHO29
ride safe
linjhun is using 90/80 front with yokos front fender...works fine and looks good too....by the way he's using trusty shox..
ride safe
m00nraker
ceejay29 said:
@moon...i think you can find fork oil at any motorcycle shops...if your near caloocan you, can buy it at exceed, tres hermanas exact, cyclemar ect...there are lots of brand but i recommend repsol fork oil...
ride safe...
thank you sir.. but im in cavite i guest look around here and maybe,luckily i can found one here in our place... but thanks to you i know now what brand will i look for.. thnak you sir ride safe in aritao..
raider125jeigh
ride safe
linjhun is using 90/80 front with yokos front fender...works fine and looks good too....by the way hes using trusty shox..
ride safe
thanks for the information ..vice do you know what bracket was used?
marcusfilter
ha ha ha....me as well, I love SOS...that's why I am still here...mwah mwah mwah...hugs and kisses...
BOSS_CHO29
@ raider...sir linjhun used ride it bracket...i think i fits well with trusty shox...there are many brands of bracket just look for the one fits your shox. ayt?
BOSS_CHO29
@marcus...im sorry but i cant understand a word on your last post...should this thread be on english only? hahaha
"parang si goff lang" ...lol
mwahhhhh....
marcusfilter
mwahhhhh....
ha ha ha..I already edited my post...sorry I forgot...ha ha ha
raider125jeigh
ah ok...i have yoshimura bracket which fit to 7 speed the only problem was the the shox were very wide...using the stock front fender...
ride it will not work with 7 speed ...hay .....problem on not being contented hahaha... thanks for the info again..ill go to yoko this week to check his front fenders...
