ady_hnr007
modified stock carb or other carb? any?
uhmmm...where in malaysia can i get this item sir?Paradox said:KIPS mean Kawasaki Integrated Powervalve System functioning same as YPVS Yamaha Power Valve System. This system control the opening-closing valve on the exhaust port which gives more power at different speed.![]()
yeah, stock with after market carb and you will go through a bunch of spark plug before you can figure out the right jet sizephl6684 said:if ur block r stock..i think its not recommend 2 have aftermarket carb..but if u use aftermarket block n carb..then it should ok...there r aftermarket carb with tps also..peace..
, which is not that much significant from stock
