ghotichooder
which is better in term of performance and in term of durability between vixion and tk valve spring?
still waiting this answer...heheee...anyone can answer this question..i very interested to knowsorry to interrupt again...
this vixion valve spring is better compare to other racing valve spring??is it??if equip with racing cam..???and racing cdi??can it support all the power given??
Gud ev bro Blaster,,,,wala bang tiktik or tumotunog na sound kapag nasa top speed kana or kapag piniga mo ng masyado ang accelerator,,ito po ang set up ko..faito cams,faito clutch spring,faito lining,brt cdi,mtrt ignition coil,lhk valve spring..kapag piniga ko ang accelerator or nasa top speed na ako parang my sinisilsil sa head ata na naririnig ko,,,anu kaya ang problema boss,,,sana matulungan mo ako,,tnx....Vixion Valve Spring users here. We installed the Vixion springs on two snipers----2010 and MX. Two different set ups but one after effect....more silent engine with higher rev limit and speed per gear. Tried LHK aftermarket springs which were taller than stock but apparently couldn't handle the Turbo cam. It seemed then that stock was better. Vixion on both bikes now.
See the comparison of the LHK valve spring (left, longer and thinner) with the Vixion valve spring (right, slightly shorter but thicker).
2010
Faito Bore kit
Faito Turbo cam
Big Valve head
Kitti CDI
Namban Pipe set
2011 MX
thanks Trax (hehehe)
old cam from the 2010 (unknown)
stock head
stock CDI
stock exhaust
So far, so good. Hope this helps
Cheers!
I agree.. we also use LHK valve springs on LHK stg2 cams. Spring is taller than stock but the stock one stiffer.Tried LHK aftermarket springs which were taller than stock but apparently couldn't handle the Turbo cam. It seemed then that stock was better. Vixion on both bikes now.
?how about the clearance of the valve bro,,,is it loosen or tighten....asa ka sa cebu kay taga mandaue ko,,,,I agree.. we also use LHK valve springs on LHK stg2 cams. Spring is taller than stock but the stock one stiffer.
My tuner recommend to get stiffer spring or just go back to stock first.
I'm choosing between Faito or Vixion valve springs to change but still back reading on Faito brand since most of my set consists of Faito already
any cebu sellers here have Vixion springs for sale?
AFAIK on stg2 camshow about the clearance of the valve bro,,,is it loosen or tighten....asa ka sa cebu kay taga mandaue ko,,,,![]()
NICE ONE SIR!!!!! WHERE TO BUY VALVE SPRING AFTER MARKET?more details soon
what best CDI brand and valve spring to be used to reach the 11,000 rpm sir..T135 speedometer in every country is NOT ACCURATE
heres a computation of speed based from rpm.
sample here is based on REAL ACCURATE SPEED computation
and not the one shown in t135 speedo.
stock cdi at 9200rpm (max limiter)
max speed @2nd gear = 71kph
max speed @3rd gear = 99kph
max speed @4th gear = 128kph
aftermarket cdi at 10,000rpm with stock valve spring
max speed @2nd gear = 77kph
max speed @3rd gear = 107kph
max speed @4th gear = 139kph
aftermarket cdi at 11,000rpm with aftermarket valve spring
note: i use 11,000rpm .
Though aftermarket valvesprings can reach higher than 11,000rpm
max speed @2nd gear = 85kph
max speed @3rd gear = 118kph
max speed @4th gear = 153kph
PHILIPPINES/INDONESIAN SPEEDOMETER T135 SPECS
note: what shown in speedometer of phil/indo t135
RPM: 11,000
max speed @2nd gear = 92kph
max speed @3rd gear = 128kph
max speed @4th gear = 166kph
all of the above are based from formula computation.
lets see the actual test![]()
hehehe,
prankly speaking lahat nmn maganda, depende s iyong panlasa o gsto,Sir sa mga cams na nagamit mo ano yung pinakamaganda? Thanks!
