:lol: 5. Piston with lubrication failure
(no signs of detonation on dome)
Piston shows scoring marks below the rings on the intake side.
Possible Cause
Snow or water has entered the engine and destroyed the oil film
if the piston has scoring on the intake and exhaust sides but the dome shows no signs of abnormal combustion, the engine has been run with too little or no oil. Check the operation of the oil injection system or the amount of oil in the premixed fuel. Also, insure proper piston clearance.
if the piston has scoring on the intake and exhaust sides, no signs of abnormal combustion on the dome and is very dark in colour, there has been a failure of the cooling system. Check the fan belt, or coolant level
etc
5a Piston with lubrication failure
Piston shows dark brown deposits all over the skirt.
Possible Cause
wrong oil quality, e.g. gear oil, automotive oil
unnecessary additives have been used in the fuel, i.e. octane boosters, high performance additives, upper cylinder lubricants, etc.
5b.Piston with lubrication failure
Possible Cause
