[TIPS] Optimum Air Fuel settings for your T135
BasTarD
sir traxx, tried it yesterday and wow...1 7/8 turns worked for me @ 1.5k idle speed..reached 80kmh 2nd gear...engines sound is crisp and somewhat throaty, watching my gas consumption..engine all stock... :p
dendenzz
i gotta try this tip. as of now my 3rd gear's top speed is 90 (tested on a flat, straight 4 km lane). i will see if its effective or not. later.......
dendenzz
almost 2 turns. i think you will see the difference much more clear later.
BasTarD
sir, big factor for me is that my bike was broken in good...the rings sealed the way it should thats why changes are much felt acutely. reading of my ODO now is 5.4k and so far so good, still in top shape! 1.6k rpm and fuel screw is 2 turns out bcoz ive upgraded my exhaust to open pipe, having plans of rejetting my stock carb to a bit larger set..by the way, still one clik start, no hard starting hehe
astroboy06
@ traxxas-modifier - is your engine stock and are you using open pipe? i'm just curious about what you said that it sounds like an R1.
botsok
what if i change my jettings to 107.5mj and 22.5pj with an open pipe? what is my prefferred settings? how many turns from full clockwise position? will it still be 2 to 2 1/2 turns?
sniperyaz
spark plug
sir traxxx how about my appearance of my spark plug i turned my air screw into 2 turns then cleaned the spark plug then used in 34 kms then returned home and now that's the appearance of my spark plug,, is it good? or bad? here are the actual pictures of my spark plug, any advice? should i adjust my air screw out or in? or remain? thanks more power
Sidro
BasTarD said:
that is if stock pa carbs mo, if nag upgrade ka na...thats another story..
paps im all in stock,, i do make 2 1/4 turns. problem i didnt yet check my spark plug... but no problems encountered yet..
I do this adjustments after a periodic maintenance conducted by 3's supermat. Pupugak pugak at hirap mag start. but after DIY on adjustments using sir traxx tips, ok na sya and so far no problem.. and tumipid na me sa gas. hehehe,, tama na kaya settings ko?,, spark plug color is the only reference for good adjustments or there is any other pref?
BasTarD
daddy sidro, aside sa chek ng sp, malalaman mo yan if may usok at ano kulay, lean is parang puti if nwalang prob sa rings ng piston, itim naman kung rich mixture ng fuel at isa pa, crisp ang high note ng sound nya at hindi pumupurot and hindi dull sound...sa running perf naman, dapat response kaagad pag bitaw mo sa throttle or arangkada agad pag birit..my 2 cents :shock:
Sidro
@bastard: paps thanks, how about yung pag high rev na me medyo malakas vibration ng body ng motmot... crisp sound high note, ibig sabihin ba nito sa high rev maririnig yung crisp sound?.. wala nman sya usok paps,, pag naka time me tingnan ko color ng spark plug tapos post ko dito.. yung pipe mo paps stock din? nka 2 1/4 turns out ako ngaun, subukan ko mamya 2turns.. hehehe
BasTarD
paps, sa bagong jettings mo, start ka sa 1 5/8 turns out kasi iba na fuel flow mo then work your way up by 1/8 turns out increments pa din to get optimum fuel settings.. :D
BasTarD
talagang mag vibrate si snipey nyan daddy sidro, power yan ng motmot natin..hehehe oo sa high rev mo maririnig ang crisp sound, hindi dull at dapat walang usok..oo start ka sa 2 turns out then work it 1/8 turn increments till you get the optimum, it varies with each bike paps...
sniperyaz
the more turning counter clockwise air adjustment screw the more carbon coated to your spark plug, the more turning clockwise the lesser of carbon coated to your spark plug.., counterclockwise the darker, clockwise the lighter spark plug,, too dark not good too light not good also, it mst be in the middle level...,,, tommorow im going to adjust from 2 i will turn it into 2 1/4 hmmm... then i will post again some pictures of 1 and 3/4....,,,
