[TIPS] Optimum Air Fuel settings for your T135
sjeevi30
hi bro, i jz tried tis trick on my bike.. i moded the air filter snorkel like wat sir haen did.. n i changed my exhaust manifold to 1.1"... but did not reset the carb.. jz 2 1/4 turns of the pilot jet... but i felt there is no changes... jz a little more pick-up.. any opinion or did i do it wrongly? plz comment........
bizzy123
Wa after adjust my bike was totaly got problem, oil consumption increased alot... Early in the morning when i m going to school the enjine keep dying, now slightly better but i wan to take my bike to tune d...
kurarensu
i notice my bike sometimes got problem.. sometimes it cant start.. i gotta keep push start at least 5x before it gets to start.. esp aft riding long journey
kurarensu
my air/fuel is alrdy on 2 1/2 turns.. idling if i turn another 1/8 - 1/4 it will be like i'm throttling while idling..
kurarensu
i haven go try increasing my idling and see whether it works.. sometimes i stil have trouble starting.. need to start many many times then can
sigea
you'll be able to hear whether your idling is too low thus making it hard to start (kena already last night), so from there you increase your idle, not alot, just a bit untill you hear your bike's idle becomes stable..
kurarensu
my bike idling alrdy quite high.. if i increase by another 1/8 it's like i'm throttle on.. that's why.. maybe i lean out my air/fuel.. cos i'm on 2 1/4 turns.. maybe i reduce to 2 1/8.. lazy to do bike as everyday rain..
sigea
Thats a good idea, just tune around till you get it, as for the rain, at least it cleans my bike haha!!
goff_d_p
Hey Traxxas, I got a question, I installed the new main and pilot jets you sent me, but it's kinda weird. I put my bike back together but when i ride, the bike chokes. that's with the racing air filter i have, But if i take off the air filter it's fine.
It's so quick that when i switch to 2nd gear the front of the bike lifts off the ground. My Brother-in-law tested it after i did the change, to make sure it was running ok, and it really was lifting off the ground when he switched to 2nd. should it really give it that much power like that?
I tried the a/f at 1 1/2 turn at first, i couldn't go past 40 in first gear, so i tried 2 full turns it was better, but still seemed like it was lagging, it's now at 3 full turns and no problems. what would be your recommendations Traxx?
blue308
@goff - bro, what size sprockets are you using? I'm planning on upping my jets also, after i decide on which air filter to go with. Just a little more fine tuning. Most of us would be happy with that kind of torque, let us know how it is on top end.
