[TIPS] Optimum Air Fuel settings for your T135
goff_d_p
Traxxas, you got your turns back wards, clock wize makes it richer, and counter clock wise makes it thinner and more air.
katano88
the near truth if you follow this thread and apply it on your bike! damn.. good but your fuel cost you higher consumption.. :( :(
King.Leoric
eloowww everybody, hey traxxas, I've tried your method, and guess what, my default setting now is 2 1/4 turns??? nobody touches the setting since I bought. I bought this oct 2007. But if I will turn fully close more, still can go but with force. (not real force of course)...But i've turned to 2 1/2 turns... should I try to give more turns? please advise
King.Leoric
X1R-Qan said:
Hai Bro TraXx,,
i need ur guidance, how can i reset my idle mixture screw to 1-1/2 turns out? :oops:
idle mixture? or you mean A/F screw?
if A/F screw, turn all the way clockwise, mark it, then turn 1 5/8 turns (that's factory setting)
G
goff_d_p35
Guest
BUT IT DEPENDS ON YOUR SPARK PLUG, AIR FILTER. SOMETIMES A GOOD FULL 2 TURNS IS ALSO A GOOD RUNNING SETTING.
SORRY CAPS
King.Leoric
2 full turns doesnt work for me. Modified air filer. so I always put back to factory setting. Hard to start MC at 2 full turns and shows lean on my spark plug....or maybe it's time for me to rejet?? ^_^
G
goff_d_p35
Guest
it might be just your bike, I am at a full 2 1/2 turn on my a/f, with simple mod's,larger Main jet, custom made air filter, Irudium plug, tip # 3 from tips and tricks II, and re-adjusted tps. I haven't been able to test my top speed yet. I just installed a new 428H chain and 16f/42r sprockets.
Not all bikes are the same, even if they come a factory assembly line.
AZ135
Every bike is different so we all just have to play around for the correct settings. Keep in mind that elevation, temperature, and humidity also effect carb settings.
yes one setting will work work with one place and it wont work in other place...
the best thing to do is to trial and error
and spark plug chop.
leadman3a
traxx man thanks alot for this tip! FAster acceleration! i felt the added power on my bike!!and i did this to my brothers sniper and he is overwhelmed!!I was able to charged him meriendang busog for ur tip!!thanks alot man!! and keep on posting helpful tips.
big poppa
Im using 2.125 turns from close, thin net air filter and jettings (135 cc) open HGM pipe/big elbow... still looking for the best set though for 150cc...
depedal
OT: is the idle and a/f settings for HC ang SemiMatic bike the same? i notice difference in the looks and position of the two screws between the two. how about in settings? (ie, default settings).
i am planning to try this, since my bike's engine dies after a few seconds. specially at night when i use the lights. (light flickers while the engine is on,.... then engine dies after some seconds of idling)
unlimited express
your idle speed is too low. you have to adjust it. About the lights flickering, I haven't encountered that. even when i'm still using stock head lights. maybe your battery needs replacement.
depedal
thanks sir. ill adjust my idle speed.
Snippy
just share my experienced to this threads
my a/f mixture is 2 1/2 turn just like sir traxx advice
.....and my observation to my fuel consumption is
when my speed is 70km/h up to 90km/h i can saved
more gas that i speed of 40km/h up to 60km/h
meaning i can saved gas when in high rev that in
lower rev????my gas is high octane gas(V-Power)
my question is why????seems like it is
contrary to wat we know that when we rev high
more gas will consume....?
