[TIPS] Optimum Air Fuel settings for your T135
bloh
kamalez said:
It would go 0-100km faster then the stock coil, if you change the racing CDI as well then it will more faster.
I have not tried with the racing CDI,so can't give much review!!!!!!
I thick you are new in the forum, so take your time to flip around
ya....thanks Kama.... :lol:
ya 1300rpm.. like frozen said and also carrot. mine 1 3/4 turn, my rpm 900+ and it still maintain its perfomance 160-170kmj. Fully standard mod. no LED, no temperature digital devices, and of course no problem at all. this is my bike and let me and HYL decide wat to do and not to do with it. okey bro?? i dun care how much vulcan 1600 idle rpm. as long i can 'cucuk' it. and beat other LCs. i would not think twist to spend even 10k for my bike~ adios.
kamalez
Hi bro - no body will spend 10K for bike mod unless he is a bike maniac!!!!!!!!
What we are discuss here are to share our thoughts and buy some stuff to enhance our bike for better performance. Thats all
It's up to us whether we want or not to mod our bikes.
If your bike can go up to 160-170kmj then its good for you and we are glad to hear that.
Cheers
CryptonX
traxxas-modifier said:
guys,
just want to share this tip to you to give your bike more power.
adjust your air/fuel mixture (this is the Pilot air screw, see chapter 3:11 of service manual)
by adjusting it to the optimum settings mentioned below, your t135 will be more powerful and better acceleration.
Give it a try, and you will see the difference :)
in the Service Manual,
Factory setting: Pilot air screw = 1-5/8 turns out
optimum setting: Pilot air screw = 2-1/4 turns out
settings will be between 2 turns upto 2-1/2 turns depending on your elevation
(meaning if you live in the mountains or in the sea level area)
if in the mountain, high elevation then you can try 2-1/2 turns.
if in the sea level, from 2 upto 2-1/4 turns.
but in my bike 2-1/4 is good.
How to do it: ( to know where is the Pilot Air screw, see chapter 3:11 of the T135 service manual)
- warm up your engine
- after warm up, turn off
- turn the PILOT AIR SCREW clockwise to until its fully close (this is called IN, because the screw is going IN)
- now mark the point where it was fully closed (that will be your mark to know if you 360 degrees or 1 turn)
- now adjust it to 2 and 1/4 turns counter clockwise (this is called out because you are making the screw going OUT)
Thats it!
its time for you to ride your bike in a highway and try it.
by the way, after i adjust my bike to optimum settings
TO REALLY KNOW IF YOU HAVE THE CORRECT AIR/FUEL MIXTURE:
see the pictures attached or check this site
your spark plug color must be rusty brown.
see Spark Plug Color Chart
My bike has lesser vibration( i mean almost no vibration especially at high speeds)
and now sounds like a Yamaha R1 :)
NOTE:
-you can also adjust the idle of your bike by turning the IDLE screw (throttle stop screw)
-1 turn means 360 degrees
- To know where is the Pilot Air screw, see chapter 3:11 of the T135 service manual.
WARNING:
- Although this setting works in my bike, DONT BLAME ME FOR WHATEVER HAPPENS TO YOUR BIKE.
-This is just a tip and guide (which works to me) it is up to you if you follow.
- it is your bike and as a bike owner we should learn how to do basic tuning of our bike.
for those are afraid of doing it
I will upload HOWTO pictures and videos tomorrow
for your reference.
hi my t135 manual doesnt have a 3.11 chapter :S can some1 take a pic of his own and post it for me plz ?? :(
CryptonX
hey cryptonx
its chapter 3 page 11
if you are looking for the picture where is the pilot air screw,
see the image attachment of the first post.
its attached there where is the pilot air screw
this is the picture
http://www.yamahat135.com/forum/download.php?id=205
my chapter 3 has only 9 pages :S ( i think the did some aconomy on pages) pff i need full details as they are writen on manual so u can do the mod plz if u can take a picture of it and post it i would be glad
rudduan
yes theres something missing on my manual also,some pictures are not there...i think theres problem when downloading it
CryptonX
guys what type u have carbirateur or fuel injection cause i have fuel injection and i think that tip u gave wont work on my ride :(
hi guys
i checked my copy it has.
total pages of the service manual is 349
try to download it again at this link
http://www.yamahat135.com/forum/viewtopic.php?t=107
if your bike is Electronic Fuel Injection, you dont need the tuning because your bikes computer
will do the tuning automatically for you.
our bike is carburetor type using mikuni vm22 carb.
MIkuni VM22 Air Screw adjustment
hi,
additional info about AIR SCREW in our carb
taken from internet;
AIR ADJUSTMENT
Problem:
When you turn the carburetor air adjustment screw in (clockwise), are you making the mixture richer or leaner? My 'A' has a tendency to want to stall when you slow down to turn a corner and have the clutch in to shift into second gear. I have set the idle up higher than it should be to avoid the stall problem. Does this seem like an idle mixture that is too lean or too rich? I have heard both opinions expressed.
Solution:
The carburetor air adjustment affects idle air mixture only. For this adjustment to work correctly you must have no air leaks around the manifold gasket (intake side) or at the carburetor. Many times the throttle shaft in the upper housing of the carburetor is worn and allows air to be drawn in around the shaft.
* To make correct a adjustment of idle air adjustment screw begin by turning the idle air screw all the way in (CW) to the seat (lightly) and then back out (CCW) 1-1/2 turns. With the spark lever in the full retard position, bring the engine to an idle. Lean the carburetor mixture a little by adjusting the dash adjusting knob for no more than 1/4 turn open.
* Now turn the idle air screw in slowly until the engine starts to stall (Note the position of the screw). It should cause the engine to start to stall out about 1/4 turn in (CW) from where you started.
* Now slowly turn the screw CCW until the engine starts to stall again. Then turn back CW to a point in between the two stall points. This should be about 1-1/2 turns from the seat.
Turning the screw CW reduces the air mixture to the idle fuel, making it a richer mixture (less air). Turning the screw CCW increases the air mixture, there by providing a leaner fuel mixture. If the screw has little or no effect it means you either have an air leak in the idle circuit (usually caused by too much wear around the throttle shaft) or if you have a windshield wiper vacuum line you may have a leak in that line. Put a 1/8" brass pipe plug in the intake manifold vacuum connection to plug it off for testing (1930/1931 only with vacuum wipers).
The problem you describe can also be caused by float level set too high. When the float level is too high the fuel level in the jets is too high and causes a rich mixture when engine vacuum is reduced (as when slowing down to turn a corner). The rich mixture floods the carburetor, causing it stall or quit at reduced speeds.
IDLE AIR ADJUST
Question:
Answer:
The carburetor air adjustment affects idle air mixture only. For this adjustment to work correctly you must have no air leaks around the manifold gasket (intake side), at the carburetor or vacuum line. Many times the throttle shaft in the upper housing of the carburetor is worn and allows air to be drawn in around the shaft. To make correct adjustment of idle air adjustment screw begin by turning the idle air screw all the way in (clockwise) to the seat (lightly) and then back out (counter-clockwise) 1-1/2 turns. With the spark lever in the full retard position, bring the engine to an idle. Lean the carburetor mixture a little by adjusting the dash adjusting knob for no more than 1/4 turn open. Now turn the idle air screw in slowly until the engine starts to stall (Note the position of the screw). It should cause the engine to start to stall out about 1/4 turn in (counter-clockwise) from where you started. Now slowly turn the screw counter-clockwise until the engine starts to stall again. Then turn back counter-clockwise to a point in between the two stall points. This should be about 1-1/2 turns from the seat. Turning the screw counter-clockwise reduces the air mixture to the idle fuel, making it a richer mixture (less air). Turning the screw counter-clockwise increases the air mixture, there by providing a leaner fuel mixture. If the screw has little or no effect it means you either have an air leak in the idle circuit (usually caused by too much wear around the throttle shaft) or if you have a windshield wiper vacuum line you may have a leak in that line. Put a 1/8" brass pipe plug in the intake manifold vacuum connection to plug it off for testing (1930/1931 only with vacuum wipers). The problem you describe can also be caused by float level set too high. When the float level is too high the fuel level in the jets is too high and causes a rich mixture when engine vacuum is reduced (as when slowing down to turn a corner). The rich mixture floods the carburetor, causing it stall or quit at reduced speeds. -- Les Andrews, 1998 Technical Director
Snipe_attack'07
Just want to share insights guys!
Ofcourse when you adjust your air counterclockwise up to 2 1/4 or 1/2 turn, the engine can breath more than the factory settings. Now, im sure the effect will be, your gas consumption will increase in traffic but will decrease in long ride. As maintaning factory settings, u can save fuel consumption traffic or long ride but with lesser pull.
I hope i was able to help in a little way. :roll:
khai2717
Question..
i just changed my pipe, n i would like to know, how my air/fuel mixture setting should be likke... cos the mechanic wasnt any help at all in tuning my carbs.. i using the standard carb by the way...
goff_d_p
Hey guys, i started having trouble with my TPS, I had my A/F adjustment at 2 1/2 tiren and when i slowed down or started to turn it would shut off the bike. I adjusted it to a full 3 turn and now my accelerationa is great, and no trouble with the TPS.
I also noticed that with the 2 1/4 to 2 1/2 turn my spark plug was really dark, with carbon on it. at my next oil change i will check the spark plug again to see how it looks. maybe we all need to turn our a/f/ to 3 turns. but i also have a thinner air filter on my bike too. so that also helps preformance.
goff_d_p
well my cousen that works for Yamaha as a machanic, said that the stock settings and the setting i was useing was too rich in fuel. causing my engine to bog when opening the throttle. after he adjusted it, no bogging, and it ran much better. you got to remember, if Yamaha factory made the setting at 1 5/8 turn for A/F and we all had to adjust it to more than 2 turns, then maybe the manual is wrong. But it also depends on the type of filter your useing, if performance filter like the K & N than you might need to make the adjustment more, just depends on type of fuel used and color of spark plug tip.
fo33il
er...actually..clockwise turn is for leaner or richer mixture?im kinda lost in this thread... :p
the more turns you have (counter clockwise) means richer mix.
less turns (clockwise) means lean.
do not go LESS THAN 1-5/8 turns as it will give lean (lack of fuel) which will make your sparkplug hotter.
