Tire Size?
Noah501
I want to change my stock tires to 110/70-15 R 100/70-15
What rim size would fit them?(maybe up to 130/70 sizes baka di pa bigbike look tires ung 110)
My tires bang ganyan ang size?
May icchange paba ako tulad ng swing arm?
Hihina ba acce/top speed pagmalaki ang tires? Gusto ko kasi big bike look. :)
yves
paps 110/80-17 yan pro medyo bigbike look na xa!
Uploaded with ImageShack.us
tolitz
hello everyone just wanna ask if its ok to have the same size of tires both front and rear using my stock mags? Im planning to use larger than the stock tires. Will it not affect my bike's performance esp. handling or cornering? Tnx and ride safe to all.
Noah501
UP for tolitz. Hihina ata acceleration pero lalakas ang top speed. Just a hypothesis. Maybe somebody could answer.
snypey16
does 110/80 x 17 fit to our rear tire? any feedback? im using no 100/80 x 17 and i want to change it to much larger tire.
chubbi
can i use 100/80 rear tire with 2.15 RB mags in stock swing arm and stock rear fender?thanks
chubbi
jangbest
your 100/80 tire will hit your rear fender, if you dont have plan for lifter go for 90/80 but if you really like to have this 100/80 tire you need to have lifter.
tabi1
bro dose it slow down the bike alot ? im already using a 166cc engine ... will they both work fine together ? whats the spec on your bike bro ? thanks
If you read the post it tells what's in the bike but basically UMA Superhead, UMA 62mm bore, UMA 32 mm carb, BRT CDI, and the other normal goodies. Slow it down heck NO, will the speedometer register lower #'s YES. For me the fatter the tire the more rubber I have on the road which is always good when you are using 2 wheels only. Tires/wheels on a car are not a big deal per say, but for a motorcycle there's nothing really more important IMHO.
