2,9k less 10%per pc, caloocansniperCJ said:alexi_2 said:90/80 F
100/80 R
Pirreli mt75
hello sir, how much pirelli tire costs sir? on that sizes..TIA
It's ok bro. I'm using Michelin 90/80 front and Swallow 90/80 rear. Looks quite well.Guys just wanna ask if what tire size should i put on my rear?
is it ok if my front is 90/80 17?
thnx! newbie here.![]()
I want to change my stock tires to 110/70-15 R 100/70-15
What rim size would fit them?(maybe up to 130/70 sizes baka di pa bigbike look tires ung 110)
My tires bang ganyan ang size?
May icchange paba ako tulad ng swing arm?
Hihina ba acce/top speed pagmalaki ang tires? Gusto ko kasi big bike look.![]()
yes sir! look at my bike above using 110/80-17 michelin pilot sportydoes 110/80 x 17 fit to our rear tire? any feedback? im using no 100/80 x 17 and i want to change it to much larger tire.
your 100/80 tire will hit your rear fender, if you dont have plan for lifter go for 90/80 but if you really like to have this 100/80 tire you need to have lifter.can i use 100/80 rear tire with 2.15 RB mags in stock swing arm and stock rear fender?thanks
I am using 120/70 on the rear (MX - not sure if it's any difference). You can see how it fits below.hello every one, i wanna use the racing boy 2.5 mag with the stock swing arm what is the max i can go ? all answers are appreciated![]()
bro dose it slow down the bike alot ? im already using a 166cc engine ... will they both work fine together ? whats the spec on your bike bro ? thanksI am using 120/70 on the rear (MX - not sure if it's any difference). You can see how it fits below.
http://www.yamahat135.com/threads/new-ride-new-looks.17130/page-2
If you read the post it tells what's in the bike but basically UMA Superhead, UMA 62mm bore, UMA 32 mm carb, BRT CDI, and the other normal goodies. Slow it down heck NO, will the speedometer register lower #'s YES. For me the fatter the tire the more rubber I have on the road which is always good when you are using 2 wheels only. Tires/wheels on a car are not a big deal per say, but for a motorcycle there's nothing really more important IMHO.bro dose it slow down the bike alot ? im already using a 166cc engine ... will they both work fine together ? whats the spec on your bike bro ? thanks
